Negative resistance via pyroclay.com material ?
Started by hartiberlin, October 02, 2007, 10:25:37 AM
RadiantEnRg
It is...you just can't see the brushes..they are enclosed...I had done it to that 12v radiator fan...but it went so fast and got so hot it melted :(
armagdn03
I dont understand your power supply circuit, are you feeding it pure dc or pulsed?
I wish I could turn my brain off sometimes, then I could get some sleep.
Tink
Do I understand it right that you take one wire from the rectified mains power and on the end the ground?
In that case you still use normal mains power because ( at least in Europe) the neutral mains wire is connected to ground at some stage.
So I don't understand what you are trying to proof to be honest.
Synergy is the key to free energy.
Super
oh man,
let me add that this is crank!
Take care of you when walking around shoeless and running this setup :D
And please more of this, never seen a huge ac motor running from only "one"  wire!
And shame on me, i must say that connection of power supply and ground is also not
clear to me  :(
is the power supply ac or dc pulse, if dc i think it would make me much more confused  ;)
and did you checked your diode, maybe it is damaged ?!?
Added: Ok RadiantEnRg, i looked closer and see ... you really described all needed parts
and now i am confused.
RadiantEnRg
Alright...here's what i did. The AC is rectified and then fed to a 400v capacitor which in turn then feeds a stepdown transformer...this cap is pulsed to the stepdown transformer. I have clipped in on the common negative of the circuit. On every off pulse the coil sends a mirrored radiant spike of positive polarity. Now this circuit is really 2...the first pulses a stepdown xformer which then pulses a lower V cap...I can take the positive of that cap and do the same thing...proving that is not just coupling with AC from ground. However it is very low potential, about 14v. I am not sure yet, it could just be coupling to ground..I am going to get an inverter and test it. However, I can sit here and hold the ground and the lead with no adverse effects at all. So I am not sure...I will have to keep testing. I just found out that nueutal is coupled to ground....so I will have to let you guys know when i do.
