Negative resistance via pyroclay.com material ?
Started by hartiberlin, October 02, 2007, 10:25:37 AM
jeffc
Quote from: RadiantEnRg on October 05, 2007, 04:42:35 PM
I have gotten some truly remarkable waveforms off of the secondary side!! Well I am going back to work, will update you guys later
@armagdn03
You are planning on replicating some of these configurations, yes?  I can't wait to see some confirmations and further meter readings!
Thanks to RadiantEnRg for being very open with his information so that we can more quickly understand the effects he has demonstrated.
jeffc
RadiantEnRg
Alright guys...I was so pissed off last night, about my false positive results from coupling with neutral, I stayed up all night and finished my circuit...I DID IT!!!
For real this time!!
I replicated the Tesla electron pump!!
Using only a 12v battery I pulsed a car ignition coil with a 555 circuit....I put a super fast 1000v diode across the negative and output..but I put it on reversed so when the off pulse Radiant Spike caomes it is diverted away from 555 and back into coil.....I then only use the one plug from the ignition coil and split it with 2 diodes, making a circular path.....I then wired a .22 cap onto across the circle and put a xenon flash bulb across that. I hooked the trigger to an ariel antenna....Guess what it worked to trigger it..It is Awesome!!!
Come check it out... http://youtube.com/profile?user=RadiantEnrG
RadiantEnRg
@dani1...There may be something to that. I noticed that gas was very porous in the middle. And as it says, when heated it is many times it's original volume. YOu guys need to come look at my new video's....it's undeniable, there is an influx of aetheric energy. By splitting the positive, I have made an asymmetry and the environment wants to balance the situation.
RadiantEnRg
Sorry, I'm a lil tired...gas=glass bead*...(negative resistant diode)...thats what I am convinced it is now, an N-type junction diode
tinu
I truly appreciate your experiments, excitement and willingness to share. My full respect to you.
On your way ahead, please consider the following: take a small 9V battery. Always in between the space of (+) and (-) there is an electric field gradient, as everyone knows. Now take either (+) or (-) and ground it. You?ve just expanded the said electric field into the whole room. Electric gradient may be very small, but as small as it is, you can definitely measure a current with a sensitive micro ammeter, as long as you close the circuit through your body and further on through the carpet, floor etc. And this is just from 9V, DC?
Replace DC with AC and you can see it on the scope. Effects are more pronounced because of capacitive coupling. (In DC it was only normal conduction through multi megohms). Increase the AC voltage and you can charge capacitors at really high voltage (although you have to wait some time as the overall power is quite small). Actually, by placing an Avramenko plug near (and not in electric contact) with the main power line, I was able to charge quite large capacitors (60-80microF) at about 308V. Theory predicts 311V for Europe (220V*sqrt(2)). That was done entirely by one wire.
What?s my point?
I?m still looking for the ?radiant energy?. But I couldn?t find it until now?
Quote from: RadiantEnRg on October 06, 2007, 03:21:24 AM
Imho and in the light of the above-described experiments (that almost everyone can try) the above statement is questionable. I wish it was true but I?d say it?s plain old-fashion electricity?
Please comment.
Tx,
Tinu
