Single Wire Tests
Started by duff, October 31, 2007, 03:42:00 AM
Bruce_TPU
Good morning All,
Some one wire experiments, that need to be run.  Including one of Marco's that still has not been tested.
ALSO, I have made a flow chart circuit for the 3 stack tpu.  Just an idea to test, for those who have wound theirs already.
My Litz has come in.  675 strands, individually insulated.  Very small wire.
Cheers,
Bruce
jeanna
My apologies, Bruce,
It is the reason the first one was a little gif.
I did think people doing this should see a picture taken from nature that I have never seen anywhere else.
jeanna
scotty1
Hi all....
These kicks you all talk about are so easy to explain.
It has nothing to do with electrons!!
It has nothing to do with collapsing fields.
It has to do with angular displacement.
It has to do with the capacitance of a wire.
Push a coil with a light bulb connected through a U shaped magnet....do it slowly and you will have no light....now do it quickly and you will have light.
This shows that the TIME is important.
When you approached the U magnet with the coil...the U magnet was loosing its strength...but when the coil breaks away from the U magnet..the U magnet is recharged from the air or the Earth's magnetic field....ready for the next start....
Your a/c power lines are similar....during the time of no pressure the wires are slightly charged in a capacitive way from the Earth...it is one of the reasons a/c can run so far....
In the a/c the pressure is rising and falling steadily so things remain fairly stable....but as Henry Moray says...."When you put a substance under pressure and then set it free"....the scene is much different....angular displacement towards capacitive state occurs instantly......but during that small amount of TIME there is alot going on in the wire.
It is the reason your CEMF is at a higher voltage.
It is the reason for all the wonderful effects of Tesla coils and disruptive discharges.
As the coil approaches the center of the U magnet...the running current stops..no pressure....but the coil wire and core are full of magnetic lines of force...at the max limit in fact.....ALL THE FLUX IS DIRECTED ACCROSS THE WIRES.....
We want the force to run along the wires....not accross them.
As soon as the coil moves away from the U magnet center, the current reverses until all the flux in the core is pushed into the wires.
By the way...for those who are experimenting....do not overlook those pictures i loaded...
The forms in those pics of mine are what you use to start your car everyday.....without those forms...you would have no electricity......
Read about magnetic currents....then you will know what electricity is......then you will know what my pics are......they are more interesting than anyone can see.... ;)
People aks for hi res...then complain about it....  funny place  ???
Scotty.
Bruce_TPU
Good morning All,
Three of the "proper" frequencies will never be enough.  They must be "driven" with a triode tube, (to start with.  It is more than just the speed of the tube, it has to do with the harmonics naturally on the output of the triodes signal.)  head long at one another.  A separate battery (power supply) for each, slightly out of phase.  Identical signals.  I would test with the infamous 245 Khz.  One of SM's given frequencies and the frequency at which lightning is formed.
The following is a repost from June 22, 2007 of two experiments mentioned by Thaelin. My comments are in (^)
Experiment #1
If you want to see this in real time, take two signal gens positive leads only. One small hobby motor and wire it to both gens. Now set the frequency's low but slightly off each other (slightly out of phase) and watch the motor rev up and down as the frequencies counter act each other.
Experiment #2
I have a bifilar coil from other things wound with a lot of wire. I put a small ninety degree coil through the center and hooked up two signals. Well not much. then I moved one of the signals to the output end and the scope went nuts.(identical signals opposing one another, different power supply's, slightly out of phase.)   Good way to see it too.
Link:  http://www.overunity.com/index.php/topic,2300.msg36492.html#msg36492
Cheers,
Bruce
hansvonlieven
Quote from: Bruce_TPU on January 28, 2008, 07:29:44 AM
Good morning All,
This is interesting Bruce,
245 KHz is the 16th octave harmonic of the Schumann frequency if you accept this at approx 7.48 Hz. It is also very close to Keely's scale of B-flat depending on which concert pitch you use (we do not know which concert pitch Keely used as A=440 as an accepted standard is of much more recent origin)
You mention several frequencies given by SM, would you please so kind as to let me have them, I would like to analyse this further.
Hans von Lieven
