Meyer's WFC concept analysed
Started by Farrah Day, October 31, 2007, 11:41:08 AM
powercat
HI Hydroman
QuoteThanks Powercat!
Cool links.
I can probably come up with any design you have in mind
my car is a 1995 ford escort 1.9 TD the cell iam looking at is SS cups    http://www.overunity.com/index.php/topic,4302.msg101240/topicseen.html#msg101240
QuoteFrom what I've seen, unless it has been quite improved, the pwmpower guy doesn't know what he's doing. Pulses all over the place, not square, AC coupled ect. Not impressed with that at all
No answer to my email from him. hmmm
QuoteHaven't looked at the others yet but I have found some real nice bench top type pulse generators out there. Very pricey but good stuff none the less. Not made for automotive use of course
Very pricey not good my car was only ? 200. not for automotive use no problem for me
QuoteAn automotive setup, if you are using standard electrolysis, would need to be automated for control of current to the cells and also to turn it on and off automatically. PWM is all that is needed. No need for the other fancy features and flexibility that the so called Lawton circuit provides as it is primarily for research purposes.
That sounds great for me and many others on the forum with crippling full cost
QuoteI can provide what you need, no problem.
I had developed a system for a different application that is ironically similar to one of Meyer's drivers that uses different chips
A friend is helping me with the electronics and i am doing the rest
QuoteFeel free to have a look at the results of my latest design.
http://hydrogencollective.com/packetpulser1.mpg
You may have to right click and select 'save target as' to view in locally on your PC.
Let me know what you think and feel free to pass it on to others.
I may post it on youtube at some point.
Yes right click and select 'save target as . One for the others on the forum (and my friend)
QuoteLet me know if I can be of help.
Yes please   (for all us beginners)
QuoteThanks
Hydroman
P.S. Where did Farrah Day go off to? Did he fall into the abyss? ;-)
Last seen here on: February 29, 2008  http://www.overunity.com/index.php/topic,3641.msg79556.html#msg79556
all the best
pc
mrgalleria
Aloha,
Sorry, I spend most of my time at oupower.com. You may want to see my project folder there, some good photos and info on cell design and plasma cell upgrades.
tulook
these are posts from a former member who has had some success with this thing and may have gone underground
ravzz
Regular Poster
Posted: Sat Aug 11, 2007 7:57 am    Post subject: Ravi's Meyer Replication- Tap Water to H2
The input to the Water Fuel Cell (WFC) was 0.51 Amps only. Just made the videos and uploaded. Its totally Pulse Voltage and Frequency based...
Video 1:
http://www.youtube.com/watch?v=2vzTzqpp-Uk
This video shows the innards of the WFC without water.
Video 2:
http://www.youtube.com/watch?v=FNJ_vjuO_ME
This video shows Freshly filled Tap Water. No other impurities (Read no Salts or Acids or anything at all...just plain tap water and not distilled water) added.
Video 3:
http://www.youtube.com/watch?v=-1lScTsHBkQ
This video is after the top is sealed and with an input of 0.5 Amps
from the Frequency Generator.
Enjoy the videos..
Back to top
ravzz
Regular Poster
Posted: Sat Aug 11, 2007 8:21 am    Post subject: Outputs
NOW THE OUTPUTS:
Presently the approximate volumetric gas discharge by an inverted
measuring flask is given below:
INPUT--H2+O2 cc/sec---H2 only cc/sec---H2 Lit/hr
0.5 A-----7.00--------------4.66-------------16.776
1.0 A-----8.66--------------5.78-------------20.808
1.5 A-----11.66-------------7.78-------------28.008
2.0 A-----14.00-------------9.33-------------33.588
3.0 A-----16.36------------10.91-------------39.276
4.0 A-----18.00------------12.00-------------43.200
*H2+O2 was calculated on an average basis for collection time of 30
secs. I'm not very sure of H2 and O2 volumes as I've calculated H2 as
2/3rd the volume of the total and O2 as 1/3rd the volume. Incase im wrong please do let me know how to calculate these.
tulook
some more on conditioning...
ravzz
Regular Poster
Posted: Mon Aug 13, 2007 6:31 am    Post subject: Hi again
For Kumaran:
I'm not very sure if you are well versed with Stanley Meyer Technology.
I would be for one thing very impressed if you could generate anywhere close to the outputs mentioned with pulsed 12 Volts and HALF an AMP!!
Please donot confuse this with the regular high ampearage electrolysis. This is low ampearage high volage pulsed electrolysis!! wherein you use the voltage potential to break down the covalent bonds and by the way the water doesnt heat up as in the regular electrolysis. The temperature rise is at the most 3 - 4 deg above ambient after about half hour of working!!
If you take a closer look at the third video you would see large bubbles of the range of 4mmto 10mm+leaving the tubes, so dont go by the more visible slow moving smaller bubbles.
To SeaMonkey and MarkinAustralia :
I initially started off with Dave's circuit.....was in touch with him to sort out a few issues with the circuits the went on to make a few improvements. You could say that Dave's circuit was the skeleton where i started off but had to make some changes. Of the original circuit i had a few burnt/blown out components and low gas generation as my setup is with 9 tubes of 9 inch lengths and his was 6 tubes of 5 inch lengths so the exposed surface areas are comparitively higher. From what I presumed Stan used tubes of 18 inches so I went for half his length but the same number as in his video.
Material used is 316L seamless pipes. Annealed for 3 hours in inert amosphere of Argon to remove all residual magnetism and cold work stresses before they are assemled. Leads used are 316L 1.2mm dia wires to all 18 pipes individually spot welded. The inner pipe is 1/2 inch longer than the outer at the bottom for the setup for connections.
You need to be very patient with the conditioning of the pipes.....it took me months to get the generation you see.
Volts x Amps = Watts
12 x 0.51 = 6.12 watts the generation is around 7 cc/sec
which coverts to 16.776 Lits / hour
16.776 x 2.4 watts (Faraday/lit/hour generation) = 40.262 Watts
Well I seem to be generating the equivalent of 40.2 watts as per Faraday with just 6.12 Watts.........I hope this answers Kumaran's question aswell.
I dont know if im right but I seem to be generating 550% excess
as the above works out to 40.2/6.12 x 100 = 656.86%
656.86 - 100 (Faraday) = 556.86% OU !!
Correct me if im wrong with the calculations.
Alright now to the crux of the situ... I dont know how long i'll be allowed to post this stuff over the net as initialy when I was in touch with Dave I had sent some pics to him and my place was raided within a few hours after the mail to him. I was kind of helped out during this time by Dave and Patrick Kelly.Though ive had success a few months ago I had not come out in the open but now Ashtweth of Panaces Bocaf has convinced me to go public as this could save me any more future harassment.....Im taking a huge chance by posting this right now.... you can see more details of the problem at
http://www.panacea-bocaf.org/EngineerinIndia.htm
The above writeup is on a few other sites aswell. This had happened some time in Jan this year.
I'll try and post a few more videos using 12 Volts 1 amp 1.5 amp.... at the earliest and post the links. Try and save the vids incase theyre removed.
tulook
and this bit...
ravzz
Regular Poster
Posted: Tue Aug 14, 2007 9:46 am    Post subject: CONDITIONING OF TUBES!!!!!
Alright guys make a note of this and save it some place
The conditioning process below was given to me by Dave Lawton and its what I followed religiously for months to reach the outputs. Consider this as the holy grail like I did and still do...
1. Donot use any resistance on the negative side when conditioning the pipes.
2. Start at 0.5 Amps on freq gen and switch off after 25 mins for 30 mins
3. Goto 1.0 Amps for 20 min and stop for 30 min
4. Goto 1.5 Amps for 15 min and stop for 20 min
5. Goto 2.0 Amps for 10 min and stop for 20 min
6. Goto 2.5 Amps for 5 min and stop for 15 min
7. Goto 3.0 Amps for 120 to 150 secs. need to check if WFC getting hot...if it does you need to reduce the time.
AFTER THE 7 STEPS ABOVE LET THE WFC STAND FOR ATLEAST AN HOUR BEFORE YOU START ALL OVER AGAIN. I used tap water for conditioning and no vinegar or any additives.... I donot know if adding something might work or not.
You would hardly see any gas generation at the beginning but it makes a lot of brown muck.....change the water after every cycle initially. DONOT touch the tubes with bare hands if the tube ends need to be cleaned of muck use a brush but donot touch!! As per my experience the brown muck if left in water for the next cycle heats up the water and you need to avoid this.
Then you see the reduction in generation of the brown stuff over a period of time and at a point the pipes dont make any brown stuff atall. You would have had very good generation of gas by now. You get a whitish powdery coat on the surfaces. Never touch the pipes with bare hands once this comes on.
DO THE CONDITIONING IN A WELL VENTILATED AREA OR PREFERRABLY CLOSE THE TOP AND VENT THE GAS OUT IN THE OPEN.
AS THE WFC IS LEFT ON FOR QUITE SOMETIME EVEN SMALL AMOUNT OF GENERATION CAN GET ACCUMULATED IN A CONSTRICTED SPACE AND COULD BE A HAZARD.
The above process to be done after annealing the pipes....see to it that no oxide formation is left on the pipes...use a detergent to wash off the pipes and rinse them thoroughly with fresh water.....assemble the setup including the leads and base.....finally flush the pipes with lots of fresh water......donot touch the pipes with bare hands after this.......
Good Luck and happy conditioning......RAVI
I'll be away for a day or two....will get to more explaining after that.
Of course this is not the whole story but i hope this helps :-X
