Meyer's WFC concept analysed
Started by Farrah Day, October 31, 2007, 11:41:08 AM
slider1
Quote from: Farlander on July 11, 2008, 07:45:00 PM
HYDROMAN WHERE ARE YOU??
KISS
That oscope readout is the KEY
I agree. I think that no matter how you get there you need the step charge, High voltage is most important. One way to get there is with your PWM into a step up transformer output that signal into a full wave bridge. Now you have the pulse train that Meyer uses. When you take that signal and feed it to a capacitor or your WFC now you will get the STEP CHARGE effect this will keep charging until you have "catastrophic failure of the dielectric, (cap shorts out) then the pulse train starts again.
canufi
Quote from: Farrah Day on November 03, 2007, 05:32:45 AM
Eg. A glass jar filled with electrolyte (water in our case), with an electrode immersed in the electrolyte in the jar, but with the other electrode on the outside of the jar. So the outer electrode could simply be a metal foil wrapped around the jar. We would then have glass as an insulator between the two electrodes. Due to the insulation properties of glass this would surely make for a relatively low loss capacitor. But then I have never seen this tried, so maybe there is a need for both electrodes to be in the electrolyte. Hence, the science is not quite as straight forward or obvious as many people would like to think.
This is impractical because Air has a dielectric breakdown. If you put the electrode outside the jar, you have to get rid of all the air since it will breakdown.  Think about it, why don't they make capacitors with the electrode outside the capacitor? Come on, don't be ridiculous.. they soak the electrode inside the capacitor.  Just because the capacitor has some impurities in it, doesn't mean it isn't a capacitor.. it's just a crappy capacitor which will break down easier, which may or may not benefit the entire process. We literally WANT the capacitor to break down to cause hydrogen production.   Water is a POOR conductor even with impurities in it, compared to something like copper.
canufi
Quote from: Farrah Day on November 23, 2007, 05:10:51 PM
And here's an interesting snippet of info.  When water ionises it is an endothermic reaction (ie, it takes energy from the environment - in the form of heat).  Does this explain why Meyer-type wfc's remain cool whilst still giving of a lot of gas!!  Definitely worthy of further consideration.
The reason Stan's device runs cool is because he is turning water into a highly conductive plasma near the electrodes, whereas in regular electrolysis the water functions as a Resistor. A conductor, is much more efficient than a resistor. Light bulbs that have more resistance, are less efficient and produce more heat.  As you heat up water, you also increase Brownian Motion which Stan may be taking advantage of which means that the free electrons get bopped around in the water due to brownian motion.
Stan may in fact be tapping into brownian motion and making a special Brownian Ratchet that functions on random movement instead of requiring specific movement. The brownian ratchet was considered a failure of perpetual motion because it doesn't perform useful work, it is random work. The idea that brownian motion is not perpetual since it is not useful work is a complete lie told by physicists to cover up the fact that brownian motion violates the thermodynamics laws.  Whether or not the motion is random or not has NOTHING to do with whether it is perpetual motion.  You can trap random movement and turn it into useful work, scientists are just too arrogant and stupid to realize how to trap the random movement so they build over simplistic devices like the Feynman Brownian Ratchet which is a straw man device.
The whole point of dielectric breakdown is to form a plasma which is ionic - spark plugs conduct electricity through air... and yes if there were minerals floating around in the air the spark plug would still work! Just because water has minerals in it doesn't mean the process is now regular electrolysis. Are you saying if air has mineral impurities in it all of a sudden spark plugs no longer function? Don't be silly - they just breakdown the air easier.
canufi
Quote from: Farrah Day on November 15, 2007, 04:52:54 PM
Classic claims don't make sense and never did to anyone that understands that tap water is a very 'good' conductor.
Tap Water is a resistor, it's not a good conductor. A good conductor is Copper.
Water is a poor conductor.
Just because you can get electrocuted in a bath tub, doesn't mean water is a good conductor.  You can get electrocuted with a resistor.. Duh!
Resistors are not great conductors.  Good conductors are plasma and copper wire.
Before criticizing Stan, you should educate yourself a bit first.
So how do you turn water into a good conductor to reduce heat? High voltage causing plasma!  Regular electrolysis did not cause plasma or good conduction using no salts or little salts as possible.  You can still form a plasma if there are impurities in the water - do you have evidence that you can't turn water into plasma if there are impurities? So if a spark plug arcs across air that has impurities or calcium particles.. the spark plug no longer works and no plasma is created? I doubt this very much.  It just means the spark plug breaks down the air easier since it finds a conductive path quicker than with pure air.
tejthemaverick
In order to build a wfc that works we need to understand the self ionization of water. its is a process occuring spontaneously and dissociated species soon recombine. this is a random process occurring all the time. now the energy required for this self dissociation of water comes from the vacuum inside the water molecule. allow me to explain the various states of water that exist in nature, of which hydrino is very important:
1. Covalent water==Steam
2. polar water==aqueous form
3. Ionised water== H2O-->(H+) + (OH)-
Now to understand the source of energy for the spontaneous dissociation of water into its ions, we have to understand the structure of the water. The bonds betwwen the oxygen atom and hydrogen atoms is covalent in nature, slightly polar. Now one of these hydrogen atoms drops to lower state below the ground state, effectively falling closer to the oxygen atom. This energy is utilised to dissociate the water. Thus an OH- ion contains oxygen atom and a hydrino atom.
Hydrino does not exist in nature, it only exists as a combined form in water. Therefore when a water molecule self ionises, one hydrogen drops below its current state and allows the dissociation of the other hydrogen atom.
Consider an electrolysis cell where one electrode, preferably anode is coated with a dielectric. Now this cell becomes a capacitor, with the water acting as a extension of the cathode
Now when the electric voltage is applied to the cell, hydrogen is produced at the cathode and the hydroxy ions pile up at the anode dielectric layer. When the voltage is removed the hydroxyl ions move towards the cathode much like a spring, releasing the electrons at the cathode, much like a typical capacitor, producing oxygen and H+ ions.
For conventional electrolysis to take place 2 electrons are required for every water molecule to be split. But what happens when only 1 electron is supplied? a hydroxyl radical will be produced(OH.). So in a water fuel cell only the cathode conducts, electrons enter the cell through the cathode and leave the cell at the cathode only. Thus the same number of electron which were supplied during charging are removed during disharge. since every electron supplied at charging produces one hydroxyl ion, same electron when discharged produces hydroxyl radical. Now since a thin layer of hydrogen seems to be adsorbed onto the cathode during charging, it reacts with the hydroxyl ions when the reach the cathode during disharge.
So overall reaction is like this:
Self ionisation
H2O---> (H+)+(OH-) (oh- is the hydrino-oxygen ion)
cATHODE
charging:
(H2O)+(1e-) ---->( H) + (OH-)
discharge
(OH-) - (1e-)---->(OH.) hydrino radical
total
(H)+(OH)---->HHO
