Hydrosonic Pump
Started by FreeEnergy, June 27, 2005, 03:47:29 AM
allcanadian
I should have mentioned as well that Victor.S made huge leaps in technology within a few years, at this exact time he was researching static generators(lord Kelvin) and hydrolysis of water vapor. From this point on he used water vapor exclusively, it was said the vapor was so fine it could only be detected with a mirror. So Im guessing a very fine water mist with large static charges applied will seperate into H and O under large centripital or centrrifugal forces. Everyone is always talking about how it is almost impossible to convert free static charges to useable power in an electrical circuit. So do away with the circuit, have the charges do work in a process, then harness the process.
Im going to start with the basic tests VS did when he started making huge leaps forward, that is oppositely charged spinning vapor streams. I don't want to hog your thread so I'll start a new one somewhere in the forum.
best regards
kukulcangod
Very interesting addition that will be.......
I've read that book I hope you are already at the group:
http://tech.groups.yahoo.com/group/viktorschaubergergroup/
You will see my effort at making a repulsin out of a radiocontrolled motor
About this treath idnick's info is unvaluable ........but for the time beign I just don't have a machine to make all of this , so I have to figure out other ways.
Good Luck
idnick
Sorry bout the screw up kukulcangod.
Google this link:
  groups.yahoo.com/group/WaterFuel1978/
Dave
"About this treath idnick's info is unvaluable "  ???  "treath"  This mean thread? Good luck. You'll find it  ;)
allcanadian
Yesterday I finally made the connection between static charge and implosion.
Brown's Gas! 2H2O2
VS used catalytic metals(copper/silver) to induce huge charges in a spinning stream of fine water vapor.
What is even more interesting is that charge(current or static charge)seperates water into 2H2O2, if you ignite the mixture with a spark it implodes by a ratio of something like 1800:1, it turns back into water without a large heat reaction. But there's more, when it implodes the electrical energy that made the gas is released as a huge static charge.So here is the reaction sequence-
- Add current or static charge to heated or rapidly moving water vapor(heat is motion)
- gasses seperate at ratio of 1:1800 Victors cold expansion? YES
- move gasses to confined area and ignite
- implosion pulls huge suction at ratio of 1800:1, gasses turn to water without large heat reaction- Victors Hot contraction? YES
- A turbine harnesses the motion of the incoming gasses to  power a generator
- The static charge initially put into the gas is released and conducted with metal piping to the incoming water vapor/air- conservation of energy
- so the electrical process in balanced but the motion of the air/water vapor is not, it is a continuous cycle.
---- But what would this machine look like??
Looks like the machine below Victor's Patent#145141 fits the bill exactly!!
IronHead
Fascinating! hmmm  where to begin.
