HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
Evil Roy Slade
@Macedonia,
I notice you are using a PLC to control some of these bits.
Just out of interest,
1.  What language is it using?
2.  Can you repeat here the first 5 lines of the code?
Thanks,
ERS
I thought I was wrong once...but I was mistaken.    Oscar Wilde.
dutchy1966
Quote from: MACEDONIA  CD on November 14, 2007, 07:14:26 PM
  THE EARTH IS MOVING  LET SAY  IN THE LEFT SAID  OK  AND HIS FREK OF MOVING IS 7,3 HZ    THE SM SAID HIS DIVICES WORK 7,8 HZ  CLOUSE TO THE  EARTH  HZ
THE POI OF HOW IS START WHIT MAG  IF YOU HAVE 2 COILS  HO WHIL MAKE  ELKTRO MAGNET FILD  JUST A SECOND  AND COILS  IS CUT  IN NOT PARALEL NOT  SERIAL ATHER WAY  << PARALE  LIKE  X >  WHAT WHILL HAPEND  THE ONE COILS  IS MAKE  ELK. MAG FIL  THE ANTHER COIL MAKE ANTHER ELK MAG FILD  BUT THIS COILS IS MPUT IN THE  IRON METAL  AND THEN THE 1 COIL AND 2 COIL IS HIS POLES IS PUT IN THIS WAY  <<LIKE  N POLE TO N POLE  THE ATHER SAID  S POLE TO SPOLE >> THIS EFECTK IS LIKE YOU HAVE TWO MAG  AND YOU CAN PUT IN TOGETHER
AND  TIS EFCT IS  POSIBILYTY TO MAKE SOME OSCILATION S IN THE SAME COILS  THIS SIMPLE PUSH  JUST SECOND  IS  GOOD TO START THE  OSCILATIONS AND WHEN IS OSCIOTAIONS BEGAIN  IN THE SAME COILS IS PRODUCED  THE INDUCTIONS OR SOME VOLTAGE  AND THIS VOLTAGE  IS HAVE ABLE TO PRODUCED AGAIN THE EL. MAG FIL   AND  THIS FILDS   S AND S  ...N AND AN  AGAING SAME PROCES
WAY IS NOT WORK UP SAID DOWN  A SAID TWO FREKFENCY  THE SAME  HZ  IS GO TO 0  OSCILATIONS  THE MOVING OF EARTH  MUST BE THE SAME MOVING OF MAG  OF TPU
ANTHER  THE MATERILASIS VERY IMPORTAT TO THIS TPU
THE COIL 2  MUST BET PUT IN THE SPECIAL MATERIAL  HO HAVE ABLE TO MAKE  AND TRANSFER THE MAG FORCE  SO FAST   TO ATHE MATERIAL  HO IS ABLE TO CHARGE MAG  FILD HO HAVE SEND THE FIRS MATERIAL
  TRANSFER MATERIAL IS  ABLE FAST TO SEND  ELKTRO ,MAG FORCES TO ANTHER  MATERILAL   HO HA ABLE TO KEEP THIS MAG SOME SECOND
TRANSER FAST MATERIAL IS  <<< SOFT  IRON THIS MATERIAL IS SEND MAG FILD  BUT DONT  KEEPT  TO HIM MAG FILD  >> A MATERIL HO KEEP THE MAG FILD  SOME SECOND  IS   IRON SIMPLE .......
THIS IS THE VERY IMPORTANT MATERIALS TO MAKE PROCES   BEAGEN
IF YOU HAVE 2 SAME MATERIAL  THE PROCES  WHILL NOT START  THE SAME MOMENT WHILL END  WHITT NO RESOLTS   IF YOU PUT 2 MATERILAS   ONE HO KEEPS THE MAG FILD  THE ANTHER  HO NOT KEEP THE MG FILD AND EASY TO TRANSFER  FAST  AND EASY CATCH THE MAG FILD THEN THE PROCES WHIL   START TO OSCILATION LIKE PERPETUMOBILE
THE ATHER DIVICES  I MEAN LIKE 10 BULB  AND  800  SM TPU
IS ANTHER
Hi Macedonia,
I try to understand your explanation. Are you telling us that we need 2 coils, not parallel and not serial. The coils need to be CROSSED? like X ????
The core is made from 2 different materials, yes?  Half is iron? (holds magnetic field?)   Other half is different? Copper (CU) ????
You put in energy in these coils.  Coils start oscillation??? North pole  -->><<--  North pole   and South pole -->> <<--South pole
Coils are fighting???  1 kick --> coils fight ----> loads of kicks???
Is this what you are trying to tell??
Let me know please....
Robert
Dom
Enough for me in theories, building time now, and its time for me now to practice what I preach......by doing
This ring was made from nylon cutting board material, there will be several more I will be building like the photo you see, then ill see what effect two rings have in all of this. The more I keep looking at the SM videos now and from long ago, its fact that there several things stand out.:-
1. two rings
2. a distance inbetween these two rings
3. magnets placed
4. 4 sections of coil
So with this in mind, I will be working to that effect.
