HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
zapnic
Quote from: MACEDONIA  CD on April 24, 2008, 06:00:22 PM
hi   this is my  simple video clip   whit   some   permanenet magnets <<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<http://www.mediafire.com/?2npmizsfxzb>>>>>>>>>>>
HERE  I LIKE  TO PROVE SOME   THINGS   ABOUT 2 SMALL  PERMANENT MAGNETS WHAT IS HAPEND  WHEN IS  PUT   IN  THE   180%
HERE IS THE SMALL   IN SOURCE   WHIT  1,5V AC WHIT IN THE FERTHY SMALL TOROID  THERE IS  THE  TWO COILS  ONE  LIKE  PRYMARY   AND  ATHRE  LIKE SECONDARY NOT SECONDARY
IF YOU MADE  THIS LIKE  YOU PUT  PRYMARY COIL AND  THEN  SECONDARY COIL   AND THEN YOU PUT THERE SIMPLE SMALL PERMANENT MAGNET   THE   VOLTAGE STAGE  AND  AMPS  STAGE  WHILL NOT  BE  INCREASE  BEACOUSE  IS NOT   I SAID  IS NOT  SIMPLE WINDING  COILS  THERE   IF YOU MADE SIMPLE   PRYMARY  AND  SECONDARY COLIS THEREAND  YOU  PUT THERE  2  PEMANET MAGNETS   YOU WHILL NOT  INCREASE  ENY KIND OF  ENERGY
<<I HAVE MADE SOME      SIMPLE  OF MY SIMPLY THEORY   IN THE PRACTICAL WAY  AND   I HAVE PROVET  THIS
YES  MAGNETS  I S ABLE TO INCREASE   THE  POWER IN ONLY  SMALL PERMANENET MAGNET
FOR EXSAMPLE   MY TEST IS  IS THIS  1,5 V   AC  MAKE  KICK THERE   WHIT  RESONANCE
AND  MAKEING  STRONGLY  VIBRATIONS
AND  ATHERE  IF I PUT  MORE STRONG  PERMAMNENT MAGNET THERE  IN THE 180%   MY   DIVICES  IS STOPING  WHIT HIS FORK    THE REASONS IS   TO BE BE TUNE  WHIT  LIKE BALANCE THE  IN  ENERGY  WHIT  ENERGY OF THIS SMALL  PERAMNENET MAGNERST  IF YOU PUT  STRONG AND STRONG MAGNET  THE ENERGY WHILL DROP  DOWN  AND   NOTHING
THIS  SIMPLE VIDEO  I SEND  IS TO PROVE THIS  MY IN ENERGY  IS CONSTANT    MY DIVICE  HAS  SMALL LOAD RESISTOR  OF 12 OHMS  I   HAVE THERE  SIMPLE  TRANSFORMATOR   220V AC    // 1,5 V   THE  INPUT  MLLI AMPS  IS   CONSTANT THERE   WHITOUT PERMANETS  MAGNET   AND  MY INPUT MLLI AMPS  IS   CONSTANT  WHEN I PUT THE   ONE SMALL PERMANENET MAGNET THEN  THE INPUT MLLI AMPLS  IS GOING JUST LITLE DOWN   AND  WHEN I PUT ATHERE SMALL PERMANENET MAGNET   THERE  MY MLLI AMPS  IS JUST LITLE  IS GOING  DRPING DOWN
FOR ALL THIS MESURMENT    THE OUT COIL HAS  ALL TIME  HAS  12 OHM RESITOR  FOR LOAD     FOR  ALL TIME THERE   MY OSCILOSCOPE  IS  PUT TO MESURING  THE  OUT COIL   WHERE IS PUT MY LOAD OF 12 OHMS   WHEN I PU MAGNET  MY VOLTGE  OF OUT COIL  IS INCREASE  20 TIMES  WHIT  LOAD  THERE    FOR ALL TAH  IS  GOOD  IS  THIS  MY IN ENRGY IS GOING DOWN   AND  MY  OUT ENRGY GOING UP    ONLY SMALL PERMANENT MAGNET
IF YOU TRAING TO MADE  LIKE  ME SIMPLE TOROIDAL  PRYMARY AND SECONDARY COIL   THRE  AND PUT MAGNET THERE  YOU CAN  NOT INCREASE  NOTHING  OF YOU VOLTGE OUT STAGE   BE SURE
THIS  IS  WINDIG THERE  IMPORTANT
THANKS FOR YOU  TIME
VAU
good job
mdmiller
I'm new here, and lack some of the technical background probably necessary to be of much good.
I've struggled through the latest Macedonia comments, and have translated the last one to "get" the message -- see attached.  I think the gist is correct, if not I'll delete.  With all due respect to Macedonia, I'm fascinated with what you are doing.
thanks - Duane
