HI MACEDONIA CD I MADE SOME LIKE TPU IS FORKING MORE THEN INPUT
Started by MACEDONIA CD, November 03, 2007, 08:50:41 PM
ramset
 With all due respect to Mac    thanks for the translation  MUCH easier to understand    Chet
Thanks Grandma
M@rcel
sparks
   Mac's untranslated word was Aether.   What is happening in his clip is that the electrons on his windings are chasing the pulse signal.  Right there is your free energy.  Then the coil core is already saturated by the pm so the magnetic field produced by the copper electrons has no place to go but where you want it to.
   Nice demo Mac.
      Try this if you have the time.   There is a mistake in this picture though!  I think Mac will find it quick.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
MACEDONIA CD
HI
OK
my engls is not good  but im traing to improving my seff ;) ;) ;)
my macedonian languege is  easy   hahahahahah to writhing
@ marcel
@marco   i hope  to see this my litle  experiment if you are here  THANKS
ok <<marcel  >.here im put sinus  50 hz  in  one coil like prymary coil like simple torodal transformator to meaning of this is
LOOK HERE CLASICAL  TRANSFORMATOR  WE  ALL YUSD  TODAY  IS FORKING LIKE  THIS
THE IN ENERGY  AND OUT ENRGY   IS  1:0,8  MAX   BUT  THERE IS THE CLASIVAL WINDIND THERE    THAT IS THE REASON  WAY IS ENERGY  SMALL THEN IN
MY SIMPLE TEST IS  TO PROVE  TWO THINGS HERE
THIS  TWO  PROVE IS MISING   ON THE  CLASICAL  TRANSFORAMATOT \\
FIRST IS THE RESONACE    TO INPUT COIL  AND  ATHERE IS THE  THIS  SMALL  PERMANENT MAGNET   HO  IS   WOW  GREAT THING
I HAVE TOLD HERE SOMTHING INTERESTENG   WHIT MY TOROID
WHEN IM PUT MAGNET  MY TOROID GENERATOR IS  START TO RINGIN    LIKE  SPEAKER  YOU MY SEE THIS  WHEN IM PUT   MAGNET  SEE THE SCOPE  MY
WHEN  I PUT  MAGNET  MY SCOPE  SHOW  THE  12 VOLTS  DIF
AND WHWN I REMOVE THE MAGNET   MY SCOPE  IS  SHOW  LITLE  DIF  OF <,0,01 VOLT
ALL THIS MEURING IS  WHIT  LOAD  12 OHM RESISTOR   A HAVE CALCULATE THIS  AND  MY ENERGY IS   18 TIMES BIGER THEN IN  ALLL MESURING  IS  WHIT  ALL TIME WHITT LOAD RESIITOR  NO FAKE   BEALEVEAT
@MARCEL   THERE IS  CLASICAL   PRYMMARY COIL   AND  SECONDARY COIL  IS NOT
I  DONT LIKE TO SAY NOW  ABOUT  MY  SECONDARY COIL  WRIT NOW   MY   LATER SOME TIME
YOU MY SEE  THIS MY  TORID   IS NOT LIKE  CLASICAL TRANSFORMATOR
YOU  SEE  IN THE  ATHERE   LIKE  <,GENERATOR >>
MY DIVICE  IS PUT CLASICALL 50 HZ    IN THE   OUT COIL I HAVE   200 HZ  LIKE  KICK   AND  THEN  IHAVE   SECOND HARMONIC  IS  433 HZ
HOW I EXPLNE  THAT IS NOT  FREKFENCY   LIKE  KICK
IS STRANGE THIS  I JUSED   SINUS  BUT I GET   KICK    200   FIRST   THEN SECOND 433  HZ??
I THING THERE  IS  ROTATION THERE  NOT  HZ
LIKE  I HAVE 50 HZ
WHEN I PUSH  ONE HALF PERIODE    IN TO THE PRYMAR COILL  THEN I HAVE IN TO THE OUT COIL   2 KICK  AND THEN I  PUT  ANTHER  HALF PERIODE   OF MY  COMPLET SINU   THE  I HAVE  ANTHER  2 KICK
AND IN THE END I HAVE   LIKE THIS
  ONE COMPLET CICLUSE  OF ONE HZ  I HAVE 4 KICK
AND  WHEN I PUT 50HZ   * 4 KICK  =  200 KICK  THAT IS   ONE  FREK   THE ATHER IS   433
YOU MY SEE THIS  MESURING   THERE IS THE ZIP FILE   UP THERE
FOR ALL OF THAT   i whill be able to make  1000  of kick   per second  only  whit  one single  complet period  of one  hz
and  whill be like this  60hz * 100 = 6000  cikcluse   like  <<s. m   said   6000 cicluse per second >>
only  whit simple  small two  permanent  magnet    placed  in the 180 %
finaly  i have sme  good  for strt  biger divice
SORY  FOR MY BAD ENGLISH I HOPE   TO MAKE BETER VIDEO   WHIT  BETER  PICS  TO SEE  BY
mdmiller
I'd like to experiment further. After digging through posts, my notes contain the following on the primary.
1. We know that the electrons is inside of copper and iron.  if we want to move the electrones we need magnetism and this magnetic field must go to the INSIDE of the material and move the INSIDE electrones.  IRON is the best catcher of magnetic field and when we move a magnet close to this we move all inside electrones in that iron.   IF WE MOVE MORE INSIDE ELECTRONES WE GET MORE POWER. (Macedonia translated - with all due respects)
2. Suppose you have 1,000 pieces of wire twelve inches long and you
run the same weak magnetic field over them all at the same
time..... you get the same flow of electrons.-SM (see picture attached)
3. If the wires are run in series then you will get the 12,000 millivolts
etc. -SM (see picture attached)
4. Thus, wrapped around a toroid (see picture attached)
Is this the correct starting point for the primary ? thanks for advice.
