What is Electricty What is Magnetics?
Started by innovation_station, November 05, 2007, 11:48:47 AM
nightlife
 I have been watching some physics lectures and I have found how some get so involved in what they are told and or taught, that their common sense must be over looking the obvious.
First off, there are no such things as electrons unless you refer to them as bits of a vibration because all electricity is, is a vibration.
Common sense tells you that a solid can not pass thru a solid. Some say it's because nothing is solid and everything is poorest, that's fine except even if so, then electrons would have to weave trough pores to go thru. That is not how electricity flows. That is impossible because nothing can have the same passage ways to insure a even flow. If the flow isn't even, we would have hot and cold spots in the wires. This tells me that the only way it can flow is by way of waves and those waves must be vibrant waves.
The think that?s drives me nuts is that I have yet to hear of anyone teaching this. WHY NOT !! Is it being stopped from being taught?
Why haven't we figured out the frequency that these vibrations flow thru? the suns vibration frequency is the one we need to have as well as a way to attract it.
Another thing I figured out was that the sun puts out vibrations in one direction and the earth in the other. That is how we get a negative and a positive. I leaned that from a lecture I watched and the teacher didn't even realize what it meant as far as it's relevancy to electricity, the earth and sun.
The earth is a vibrant energy source and the sun is a vibrant energy source. The suns vibrant energy it much greater then the earths mainly due to the size and action difference. The sun is continuously exploding through out where as the earth only does so beneath the earths surface.
The suns vibrations are so intense, they pass through our atmosphere creating light when one side of the earth faces the sun. The suns vibrations are absorbed by the earths surface. The earth puts out vibrations in opposite way that the sun does when they are facing each other. The two vibrations collide and give us light and heat. The same with all living things, they all put out vibrations.
Now we get in to those things that are not alive. They must have been alive at some point and at that point, they must have had a vibrant energy. That vibrant energy's frequency can be applied to the object to split, twist or bend it, depending on the way the vibrant force is applied.
This explains why we have so many frequency?s and why some are illegal to use.
There is no way a 9th grade drop out could figure this out and not some of our top scientist. Why are they trying to hide this from us?
Before I said that electricity is nothing more then a flow of resistance which still stands all though, the flow of resistance does create a vibration that flows in direction of the resistance applied. This could also mean that electricity can be created in both directions as long as the resistance used is flown in opposite directions, this would give us a negative and positive where as if only flown in one direction, we would only get a positive.
I am still trying to get some bugs worked out in my head about this but I do feel I am now going in the right direction.
There is still much to learn with this concept and I will post more as I figure them out.
nightlife
Localjoe, its not magnetic, its vibrant. A magnet is created by two vibrations applied from different directions. The vibrations stay in motion from them repelling each other and they stay attached due to the core being charged with the vibrations. This is why substances that are made of the same substances as the magnets core, are attracted to the magnet.
Think about it.
