Harmonic Oscillating Power Electric generator video
Started by hartiberlin, June 27, 2005, 07:37:55 AM
gast
More important is the information about the winding-orientation of the coils!
In Jims last update of the HOPE-Manual I miss this info.
Not that I rebuild this generator already the next days, but this could
be a source of error for a rebuild.
Regards, Gast
PS: Stefan, what do you think?: To get compareable result of voltages on input and output of the HOPE-generator (when it runs on AC feeding with sound) Jim have to rectify the AC to DC and meassure the DC volts/amperes.
Markus
Kator01
Hi Jim and Stephan,
Three questions here :
1) wiring-configuration
2) simple calorimetric test ( also not performed by Jln-Labs )
3) to BushWacker : power-output of your soundcard ?
1)
"Initial  Wiring  Configuration  for  the  HOPE  Generator" above sub-heading : "Step #15".
In this diagramm two violett-Lines from Stereo Audio Output ( right Channel Bare and Left Channel -White)
lead to a connector-point which leads to where ? These connectors are outside the "connector strips"
2) It interesting that JLN-Labs stopped the MEG-Device-Activities at the same point :
   Using fluorescent bulbs for Power-Output-Tests. Nothing else happended after this point only vague
   statements by Bearden about problems which seem to be unsolvable.
   It is not possible to make a clear statement of the effective power flowing into these bulbs, only
   estimating by comparing the brightness to normal powered fluorescent bulbs.
   The best way would be a thermal-restistor heating up a definite amount (volume) of water in a given
   period, measuring the temperature-difference and calculate the power in Joule-Dimension.
   I would advice all interested folks to wait until this test or the one Stephan has proposed is performed and prooves
   cop > 1. Otherwise a lot of people waste time and money in order to find out later that
   they face the same problem as Jln-Labs. This test is a minimum-demand which can be done by the inventor.
   Why should a lot of people start building this device all over again ? It exists already and additional testing
   does not need that amount of effort than to build 10 new HOPE-Devices.
3) To Jim : What is the poweroutput of your soundcard ?
Kator01
hartiberlin
>"In this diagramm two violett-Lines from Stereo Audio Output ( right Channel Bare and Left Channel -White)
It seems these are the ground lines from both amplifier channels and are tied there together
at this ground shielding plate.
He drives only the upper right and the lower left small coil in SERIES and
this might be the trick, that as the fluxchange is compensating this way the
input coils are not affected by the changing output coils and this no more
power is drawn from the input, when the output changes !
hartiberlin
Jim writes:
Hi Stefan,
    This latest update on the HOPE assembly instructions is an important update. I am in the middle of building a second unit and found that the 1 inch disc magnets will not work. There would be no room for the primary coils to fit in there proper places if someone were to try and use 1" diameter magnets unless they were to make the output coils spools .50" shorter width-wise. There is a way around this but I don't have the time to write an extended version of the instructions at this time. There are also a few other minor changes. BTW, I tried a small mini amplifier unit that is sold at Radio Shack here in the states, and the feedback from this little thing is enough to kick up the voltage to 180v. I can hardly wait to see what we can do with better amp circuit which is tuned to the proper feedback frequency, but I guess I have to.
Cheers,
Jim
