Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
dean_mcgowan
Quote from: CTG Labs on November 20, 2007, 01:21:49 PM
I would understand your point if it weren't for the fact I told everyone from the start that it wasn't real and I took it down moments after posting it.  I never claimed that it was real though...!
In any case I am sorry you feel that way and I apologise to anyone else who I offended at that time.  After a year out to go back to study I was about to re-launch myself back in to experimentation.  Perhaps I should re-consider my decision to do this...
(expecting a comment from the infamous Dean McGowan now...)
Regards,
Dave.
I always enjoyed your wealth of knowledge and contributions. We all fall of the rails sometimes ;)
Welcome back.
Bruce_TPU
@ Duff
It could be because my ferrite is different and wound differently, I do not know.  I am including a full "top down" picture.  C is a 1.5 uf.  EM suggested a 2.2 uf but I can't get a hold of one of those until tomorrow.
My transistors are indeed reversed.  I touch my leads to a nine volt battery for a second and it is off and running.  I tried to add a 'third' transistor, but nothing happened at all, that I could see.  The LED would not light or blink at all.
I have added two more 1000 mf caps in parallel with the first one.  So two are electrolytic and one is not.  I do not know if this is "cheating" or not,  ;D  but it increased my run time from 18 minute 2 seconds to my new record for no battery as 38 minutes 5 seconds.
EDIT:  I have removed one of the 1000 uf caps and am testing with only two of them in parallel.  I have removed the non electrolytic capacitor.  The LED would not light just with it alone, so I speculate it may not be doing any good there at all.  I will post the time trial upon completion.
duff
Quote from: btentzer on November 20, 2007, 11:36:01 PM
@ Duff
Bruce,
You can think of your 1000uF caps as the battery, so if you have two in parallel you have 2000uf and that would account for the longer run time...
As for the circuit working with the transistor reversed I really don't understand how.
Can you read the exact part number off the transistor? I know you said radio shack npn 200 but I don't think that is the full number.
-Duff
Bruce_TPU
With the use of only two electrolytic capacitors, rated both at 1000 uf and the removal of the non electrolytic third cap in parallel, the finshed run time was 36 minutes, 44 seconds.
Cheers,
Bruce
EDIT:  @ Duff
it says NPN Type switching transistors (pkg of 15)
Silicon:  NPN
typical hfe      200
Vce    30V
Ic       800ma
Power dissipation: 1.8W
ALSO, I now have one transistor facing one way and the other facing the opposite direction in parallel and the LED is blinking away.   ;D  I don't know what this means, either, but it is fun.  LOL
innovation_station
nice work guys
i think if you look hard enough you will find a unit verry simple and far more powerful already posted
;D
  with 1 flick or 2 i put 100's volts into a cap i could drain off for hours lol!!!
never mine loop a small fraction back in to do it agin  ;D
but it is what we learn that matters  ;)
keep up the great work !!!!
isteam!!
