Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
wattsup
@plengo
Stick around. The party has only started.
@4Tesla
Finally spoke with OSE and my order left there yesterday. Dashing through the snow.....
My snowblower is on the blink. Guess my chiro will hear from me soon.
Bruce_TPU
@ Plengo
How well did you short your rechargable battery?  I am shorting my new one with 120 ohm resistor.  But when I remove the resistor, when voltage is zero, the battery will quickly recover it's voltage.
So, knowing this, my question is, are you sure it is the circuit recharging the battery, and not just a function of the battery recovering as it does, due to its chemical nature?  And, how do you know that?  Have you just left the battery alone, and see if it recovers voltage over time?
Thanks!
Holiday Cheers,
Bruce
EDIT:
I may not need to replicate Plengo's circuit, and let me explain why.  I measured my new rechargable battery, whose voltage read 7.54 volts.  I placed it on a 130 Ohm resistor for several hours to discharge.  Voltage was at 2.54 volts.  I then wrapped my one turn silver plated wire around the trigger, to increase the brightness and frequency of LED's on/off times.  I used my rechargable battery to start the oscillator and left it connected.
Now, about 1 hour later, the voltage is 5.95 volts and climbing.  I will keep everyone posted.
EDIT:
9:27 CST          6.34 volts
9:37 CST          6.47 volts
supersam
@plengo and bruce,
interesting to say the least.  great work!!!!
lol
sam
Bruce_TPU
9:27 CST          6.34 volts          11:07        6.93 volts
9:37 CST          6.47 volts          11:17        6.95 volts
9:47 CST          6.58 volts              NOTE:  I am running 5 LED's.  The first three are in parallel,
                                                               the second two are in series.  Also, as the charging slows
9:57 CST          6.66 volts                          I am more and more encouraged, because as the battery
                                                               charges, its resistance increases, so it may take the rest
10:07 CST        6.71 volts                          of the night to charge to its full capacity.  We will see!  ;D
10:17 CST        6.76 volts          11:27        6.97 volts
10:27 CST        6.81 volts          11:37        6.99 volts
10:37 CST        6.85 volts          11:47        7.00 volts     ;D
10:47 CST        6.88 volts               NOTE:  I am heading for bed as charging slows to a trickle as
        resistance build.  I will leave it to run all night and post
10:57 CST        6.91 volts                           what it is reading in the morning.
        When the battery is fully charged, I will place it again on
        a resistor and drain it and do it again.
        Also, I have been using the 250uf cap for tonight.  A
        future experiment would be to use the 1000uf cap and
        see if that changes the speed of the charging effect.
Good night!
Holiday Cheers,
Bruce
4Tesla
I found this great site for buying magnets:
http://www.kjmagnetics.com/categories.asp (@wattsup - I trust this site  ;))
Using a ring magnet for a core.. interesting idea.
4Tesla
