Self Running Micro TPU, with closed loop.
Started by EMdevices, November 12, 2007, 11:49:58 PM
Bruce_TPU
Quote from: EMdevices on November 20, 2007, 01:23:47 PM
Bruce, are you using PNP transistors?    It would seem you have to from your description, else, you must have a different connection.    You can put the coil in the Collector circuit or the Emitter circuit, but that's different then reversing the Collector and Emiter from my diagram.    then you will have an Emitter hooked up to the (+) side, is that what you have?
abassign,  I played around with the capacitors,  read my explanation.  Do you know what a RC time constant is?  If you use smaller capacitors they charge faster and hence the frequency is HIGHER.   Read up on Relaxation oscillators.
singerxyz, nobody is faking anything here, we are trying to find the "cure", I'm with you on the state of affairs in the world and the need for change.
EM
Hi EM,
I am using Radio Shack, NPN 200 type transistors.
It was a shock that two worked so well!
Bruce
Bruce_TPU
wattsup
@EM
I totally forgot a LED is also a diode. (Slap on the forehead, eyes rolled upwards.)
@btenzer
From the photo, did you just place the second diode in parallel to the first one.
Also, where did you get your ferrite. I looks really nice and thick.
Bruce_TPU
@ Wattsup
I bought the ferrite from Electronics Parts Outlet (EPO) in Houston, TX.  It is nice, for 1.99 US
And yes, both transistors are in parallel and reversed from the drawing, as far as emitter and collector.
Cheers,
Bruce
duff
Quote from: btentzer on November 20, 2007, 11:48:56 AM
Hello all,
Perhaps a minor little discovery.  I reversed the transistor, leaving the base the same, but changing the emitter wire to the collector and the collector wire to the emitter.  It made the LED much brighter, and doubled the run time.
EM or Duff, perhaps you can try this and verify.  Thank you.
Cheers,
Bruce
@Bruce
I spite of thinking it wouldn't work I tried it any way.
Sorry to report my circuit will not run in that config....
-Duff
