alternator for generator!!
Started by avr3, November 25, 2007, 08:32:24 PM
Ren
Good luck in your attempts avr. May I suggest making the switch as frictionless and hardy as possible. As I'm sure you're aware mechanical switching is prone to wear over time resulting in failure. I built my first pulse motor with a mechanical microswitch. It worked great and gave me some insights into what was happening in my rotor. However, after a few thousand cycles the switch would fail, especially at higher speeds.
Have you considered a form of commutation? I am a little unsure as to what the purpose of your switch is when I read your posts...?
Paul-R
Quote from: avr3 on November 25, 2007, 08:32:24 PM
i know alternator is the worst to use to make electricity but it is a challange that i need undestand y not!
i know that in order for the alter. to create elec. it needs the rotor exited, so in return it is wasting energy, i totaly understand. but i need to try!
I wonder if you shuld be thinking of a permanent magnet generator:
http://www.scoraigwind.com/pmgbooklet/itpmg.pdf
http://www.topgreen.co.uk/windpower1/pmg_alternator_const1.html
Paul.
avr3
Quote from: Paul-R on November 28, 2007, 11:35:08 AM
Paul.
thanks Paul, i know about the PM Gen, i just want to help the ones in Countries or Areas that can only can get a regular alternator, an d yes it is a challange but lets see what we can do!!..
regarsd
avr3
oh, yes, Thanks Ren, i have  been there and it is a great info site.
