Ideas on building a better TPU not just copying SM's
Started by sparks, December 03, 2007, 10:18:25 AM
sparks
       The tpu works by creating it's own gravitational field.  The gyroscopic phenomenom SM talks about is evidence of this.  The magnetic shell around the tpu is also proven by the use of his ammeter in the video.  The unit overheats because there is a surplus flow of energy into the collector ring probably well over the 800 watts he is drawing.  Having this in mind please contemplate ways of improving this experimental design.  Please remember safety first.  There has to be a way limit the amount of energy entering the ring current or it is going to overheat big time.
      My first idea is to use a ring to establish the gravitational/magnetic profile necessary .  THE RING AND VORTEX INITIATOR WINDING MUST BE CAGED .  The cage should be made of stone so that there is a limited amount of electrons that can reach the ring.  We are talking about MANIPULATING GRAVITY.  A farady cage won't do squat.    The cage should not even allow light in.  You should only need one kicker coil and one scource of high frequency energy to drive the initiator winding since you don't have the problem of the "collector" winding being an open circuit.
      I think the best shape of the stone or ceramic box  is a cone.
What do you guys think would be the best way to cage the ring?
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Grumpy
        -Frank Edwards
devilzangel
First a preface on the title used:
firstly, SM hasn't handed over a schematic with a building manual. so it is not called "copying". Even if we were trying to "copy", humankind has a full right to this advancement; it isn't a privilege, it should be a right.
secondly, manipulating gravity isn't such a big deal. Plus nature is self correcting.
thirdly, the Faraday cage is meant as a "safety" measure for "humans"; to block out severe radiation that can immediately hurt a human. Think about the amount of RF frequencies already in the air around you right now. Unless you are thinking that a TPU will create a dimensional rift that can unexpectedly expand to physically hurt the operator, I don't know what you are complaining about.
one could imagine how cavemen felt about "fire" when it was accidentally discovered. Something that burns, destroys, and can suffocate in closed spaces? I am sure the cavemen were shitting their "pants", if u will, when trying to harness fire. I am also sure that hundreds experienced accidents initially.
1. The energy pulled is from the quantum aether. The potential energy in a tea spoon of vacuum is enough to vaporize all the oceans on Earth. I doubt putting a stone chassis or housing will change that.
2. The gyroscopic evidence can have a few causes, gravity is only one. It is the vortex, that is causing the gyroscopic evidence. Would you classify water flowing down a funnel downward in the form of a vortex as a gravitational field?? nope. Gravity has something to do with it, but the whole form isnt a gravitational field. Vortexes can be formed in many ways. The question is what is this vortex made up of, and how does it tap into the radiant free energy.
3. I think the only way to harness the gravitational fields produced (if infact there is a gravitational field produced, I think what is produced is simply an energy vortex that is nongravitational in nature) is via force fields, either magnetic or otherwise. I know, this sounds so "star trekish." I think this is already part of the SM model. The ring structure both acts like a creator and "container" of the field or vortex created in order to extract this energy.
4. What SM has done is create a TPU in such a way that it would auto self destruct in case a runaway was about to happen. By auto self destruct, the material used would disintegrate and stop the flow. In affect, the runaway effect is dependent on the capability of the material that makes it. It basically acts like a "fuse".
When talking about the behavior of material in such conditions, the best thing to do is to do an experiment and see if you are correct. Try of stone and ceramics and see what it does. OR you can try to search academic papers to see if this type of research has already been done.
Sparks, I think you have some good points, but I think your "fear" of individuals working on this is without foundation.
Forgive my forwardness if it offends you.
devilzangel
starcruiser
The TPU is a transformer, a converter, an amplifier and a receiver. It does all this using metallic material (coils and capacitors). The question is how to orientate these items to create the device. We have clues all over the place. Leedskin has shown us, SM has shown us, as well as Tesla and others. Look at their works and see what they have in common. Grumpy sees this, I see this, we need to do the work to figure out how to take this information and put together a working model/device.
There are several ways to do this and many have already done this using their own take on how to put these elements together. See the above names, and others.
I have my ideas and I am sure others have theirs as well. I am also sure we will share our ideas when we have validated them with a simple experiment or two. I am not in this for the money, I want to figure this out to know and to share, hopefully with the right people!
I see the similarities of these devices that have been published and I am beginning to understand why the info is not just given (most would not understand or find fault with the explanation!). So this means those who want to understand  how to make one of these devices needs to study and see the light themselves! How the devices work do not fit into the "normal" Physics as we have been taught.
Well I will get off of my soap box for now. I am very excited to work on my ideas and see if they bear fruit or energy!
Remember nature is balance and to get energy you need to upset that balance or at least tap into it.
Regards,
Carl
sparks
     I take no offense at any criticism that is constructive.   I constructed an experimental device that worked using 4 watts input to get  20 watts output.  There was a bad match between the kicker coil and the high frequency power supply and it burnt out the supply after about 2 hours of operation.
This was enough to satisfy my curiousity as to the validity of SM's device.
I then spent many hours on this site studying the other experimental devices
in construction as well as reviewing SM's demonstration tapes.  I then posted a theory as to what I believe to be the underlying dynamics in this devices operation.   The next step is to support this theory with more experimentation.  I also realized that if my theory is correct this device is the
greatest discovery in centuries.  I am in total agreement that this knowlege belongs to all mankind.  It should not be squirreled away and put on some govenments patent office back shelf for personal gain of any individual or government.  Mankind does have a right to this knowlege.
      I post here about inherent danger of this machine only because of the amount of power this device is able to concentrate.  I advocate caution in experimentation because of this.   I would ask those with a working tpu to house the tpu in such a way as to limit the amount of energy available to the tpu.  A grain of prevention is worth a pound of cure.  If just housing the tpu in a slate box stops the tpu operation then it proves my theory.  I believe that the collection of energy should be at the poles of the magnetic field created by the ring, which could be accomplished by placement of a large capacitor plate on top of the ring near the apex of the torroidal magnetic field.  The earth is a big tpu collecting hydrogen ions that are accelerated along it's magnetic railroad to the poles and emitted as a plasmic flow of hydrogen ions traveling thousands of miles into space.  The interaction of these ions and the solar radiated energy causes the northern lights.  But I digress.
     I personally am unable to build a tpu experimental unit, my loved ones are starting to doubt my sanity. ::)   I do intend to monitor and contribute to this site as much as I can.  How to present this knowlege to the world I must leave in the hands of others,  for I am just a smart monkey not a divine power.  I do believe a SAFE, efficient, working model needs to be developed and then a demonstration of it working should be released to every newspaper, internet site, television station, radio station as can be arranged.
     What do ya think and feel about all the above?
@devilsangel
    The fuse is a great idea.  Perhaps a solid ring with a transistor somewhere along the diameter would be a way to control the ring current.
I also believe that the gravity generator could take on the form of an oscillating electrical or pressure field.  This thing is starting to look more and more like the golden box described in ancient writings found inside pyramids with current traveling between two electrodes on each end of the box.  :o
Think Legacy
Spread the Love
