Pentagon structure uses zero point energy vacuum??
Started by Captcaveman4201, December 05, 2007, 01:34:18 AM
Captcaveman4201
They say that if you are 1 step ahead of the crowd you are considered a genius, but if 2 steps ahead you a considered crazy. The Pentagon uses the Zero point energy quantum vacuum. The explosion that we all seen on 9/11/01 was caused by this.  Now some of you might be saying thats impossible !!! its just a building.  But consider this, a magnifying glass doesn't have any moving parts to speak of. But depending on how you position it you can make it focus the energy's of the Universe to cause a reaction to happen at a designated point. example you place the magnifying glass a certain distance above a piece of wood outside. So as when the energy's of the Universe focus at a certain TIME/SPACE .in this case when the Sun focuses on the lens at noon when it is directly overhead. The Pentagon structure/device has 5 sides and 5 rings. And in the middle is a shaft that goes straight down the middle. This is where the zero point quantum vacuum happens, It work by generating a sort of tug of war between positive and negative energy's. Both energy's continue the tug of war on a long enough timeline that the rope finely snaps. The result is an electromagnetic energy field that goes rushing back to the vacuum.  coincidences are one thing but after awhile SO many of them and that is a pattern. SO here is a few of the questions that this explanation answers. 1- how they didn't find major parts of a 747   2- the holes in the side of the structure were not consistant to that of a 747  3- there was only one video camera pointed at that spot, that didn't show a 747 but instead showed a blur  4 - other video tapes were confiscated that had a view of that area   5 - that part of the pentagon was under construction 6- books and wooden furniture near the blast area we not burned at all ( this would be consistant with an energy field for that the heat and explosion would be from friction and not jet fuel)  7- my personal favorate is that the event happend 60 years to the day of the structure's creation. i can go on and on with things that don't add up with the official version of the event. But You might say OK even if that is possible why would they do that to their own building. And then cover it up?  There is a good reason behind that also. And i will go into that at a later time in detail But for now know that. It is SO we have a smooth transition into this next era we are entering, instead of a crash landing SO to speak. SO take a look at my diagram and share your thoughts on mine. ( a description of the diagram is basically showing the spiral of TIME/SPACE with the very biggest thing on the outside of the spiral and the smallest possible thing in inner part of the spiral. The line connecting the two TIMES is the focusing of the energy.
Captcaveman4201
nobody has any comments about this? does it not answer questions?
Eden
Quote from: Captcaveman4201 on December 07, 2007, 04:20:40 AM
hi Captcaveman,
the text in the picture you attached is not legible.
could you please post a clearer one?
thanks
dean_mcgowan
Thankyou capt'n caveman,
You have taken this forum to a whole new level
Cheers,
Dean
acp
I would recommend laying off the wacky backy for a while.
