Negative Pulse Application [Cold pulse]
Started by libra_spirit, December 25, 2007, 05:35:46 AM
libra_spirit
Scope waves forms, also quite basic. The big surprise the DC output over about 12 Mhz.
otto
Hello Dave,
your picture is great.
Maybe you should try to use more turns for your controls. Here a few ideas:
1.Change your triangle form into a water drop form (egg form) but be careful because such a collector is heating up.
2. With a round collector coil.Connect 12VDC from a power supply to 1 end of the control coils. You have then 3 hot coils, the coil where the 12VDC is connected is the hottest.
3.Then connect this 12VDC BETWEEN  2 control coils and feel or better measure the temperature of the 3 control coils.
Of course I made such tests and got 1 hot control coil and 2 cold controls or 2 hot controls and 1 cold......use just square waves.
Now the million dollar question: do we really need fast pulses??? NO!!
Im pulsing now my TPU with "something" like a combination of kicks - sine waves with a very slow rising - falling time of the signals and I have the same good light on my bulb. It depends how the 3 collectors are connected, nothing else.
Otto
PS: I almost forgot: try to connect the controls and the collector in series. Can you measure the magnetic field?
libra_spirit
Mark,
Nice to meet you,
Very impressed with your spinor work. Will have to take some time to fully read through it. Right off it looks a lot like the pictures in Occult physics, what the psi guys have been seeing when they look inwards.
As to the question "Where does the energy come from?" Inside matter of corse, where else could it come from? Anyway that we use to capture it, will involve manipulation of matter, a device. The big question is how is it transferred and how do the EM fields interact with it?
Just how does matter operate?
My present feeling is that it crosses the "octaves" at the node points of the torsion fields when they hit platonic resonance. The electron shell is about 1000 octaves above the nuclear mass outer layer [proton shell]. A direct EM frequency link is impossible anyway, because both are spinning opposing directions, E field is running parallel, and frequencies are not constant. As the magnetic field changes so do all the NMR rates. It is only with the platonic vibrational structure that I can see any way for energy to move out [outflow] or in [inflow] between non harmonic frequency sets. This is the focal point between density layers. The infamous longitudinal wave moving 90 degrees to the shells resonant flows as the tips or nodes of the vibrations, the photon path. [Gravity or tempic field call it what you will] alters the time flow rate or c. This is the explination for the upwards surge of velocity in UFO craft, but also fits the TPU as well, [electrons that seem to be moving way too fast for the valence orbit exchange rate energy of normal wire].
Gravity is a "tempic field gradient with an E vector force attached" a TE field where c is now a varible. EM is an E vector in a constant tempic field, in motion. The tempic field has the ability to bend light velocity [density gradient], and basically EM does not. This only has to do with distance however.
This is nuclear energy that does not destroy the atom, but is normally present. Opening an outflow alows the nucleus, which is trying to hold the atom together and regulate electron shell distances with diamagnetic and magnetic forces, to expend extra energy we can capture. Since spin is the root force, powered from source, it would apear to be inexhaustable. Spin is captured as torsion or torsion fields. Turning it back into EM is however a great challenge.
With Joe cell work I realized there are "cold electrons" as they will follow the positive lead back to the battery and destroy the electrolites if allowed to reach it. Thus electrons can exist in more then one state of tempic charge, or in different densities as can copper.
The vocabulary is the result of much investigation into models from both spiritual and physics sources, but Wilbert Smith is credited for giving us the tempic field model where c becomes a varible, and also starting with consciousness or awareness preceeding the physical reality.
What ever the model we choose to visualize all this, we must all begin to agree on a few basic points from the TPU successes. Energy can be drawn from the diamagnetic elements [copper aluminum bismuth hydrogen], and it requires a harmonic play of vibrations, which can be coupled to an electron propelling torsion force manipulation. TPU is 100 percent copper, there is little doubt what this means to me.
With copper we can anchor the E field and generate torsion [wire], or we can anchor the torsion and transfer motion [Utron]. If we open a tempic field gradient [gravity] then the time flow rate is altered and space is charged over an area around our device, to another density.
This experiment has shown me what all the 90 degree alignments in all these devices is all about, after many years of studying and pondering them. In Electronics 101 there is little if anything on 90 degree coil setups, and even less on scalar cancelling coils! LOL!
The power in the AC is passing through the coils network, the power in the DC component is a side effect adding more energy. The coil network is OU, just as are the NMR pulses when totaled. Even with one side of the circuit opened the DC appears.
It would be a great accomplishment to actually come up with formulas for design of opening these outflows or inflows of energy, and methods to couple it effeciently and control it better.
Dave L
Quote from: MarkSnoswell on December 27, 2007, 06:24:26 PM
Hi David,
   Can you provide photographs of your experimental setup and scope traces?
thanks
mark.
PS. I'll email directly.
libra_spirit
Good ideas Otto,
I will work with them as I get time and equipment, thanks.
First trying a pure sine wave, the DC component is still present but far lower voltage is getting through the coil network at 15 Mhz. The square wave is probably generating all the correct harmonics for me, rather then using the 3 exact ones.
Cold coils:
Because working with only three control coils you can only have one reversed in magnetic polarity, then all will not run cold.
Best guess, if you want your control coils to all run cold you will need six of them on the ring, every other one will be reversed, then the tempic field between them should all be in opposing spin and more energy will move through the torsion fields. This takes us down to the vector equilibrium model [Bucky Fuller]!  The core center of tempic field vectors.
I do not know if this will create cold energy but I can see why the six points may have advantage now. The spacing between all the six coils must be accurate, all the same for the harmonic platonic resonance to form. Searl used sets of 12.
My control coils are 6 turns because here is where I could feel a torsion resonance between them and the collector coil. With this mass ratio, the torsion is already coupled, so I need far less EM energy to transfer energy between them. When you get the mass balanced you can sense the torsion flow. [This is from work with scalar coils.] The first bigger coil I built did not have this ratio correct but still does work for the DC output.
The amazing thing is that I have not connected my 12 volts to these coils yet, but was just studying thier NMR qualities, and torsion field output. I have already done the finger coil experiment with a light bulb, but have yet to build my pulsing circuitry to get the bulb to light up very bright.
The reason for straightening the wire between the control coils into a triangle, is so the torsion fields can pass between them with less resistance.
Torsion will propagate better along a straight wire, or at a sharp turn of the correct angle. If one wants to tap the torsion energy then these node points become obvious, and angles are already set up to aid the flow [longitudinal waves]. If the energy is comming up through the platonic resonance of copper, then these angles would be the best conduit. One long straight copper mass can thus generate one torsion angle, and a spin field coherence will form. The 90 degree coil at the center will alter the spin angle of the entire nuclear mass, as well as its density. This was my thinking in trying this setup from work done with the tube devices.
Dave L
Quote from: otto on December 28, 2007, 03:34:16 AM
Hello Dave,
Otto
otto
Hello all,
@Dave,
I forgot: your controls should be wound in the manner that there is a gap between the control coil and the collector. If the diameter of your collector is for example 1cm then your control coil should have the inner diameter greater than 1cm, maybe 1.5 or 2cm. In this way the field can rotate without be "disturbed" by the control coils.
Another point: try to have really sharp edges of the collector.
Otto
