Muller Dynamo
0 Members and 57 Guests are viewing this topic.
bolt
Quote from: minoly on June 07, 2011, 09:20:12 AM
This is interesting, I must be doing something wrong.
I have a pickup/gen coil, goes directly to a FWBR then to a 12 volt bulb which is in parallel with a cap. this is the normal part, the bulb lights a little. when I put my voltmeter across the bulb, the voltage reads 2.03 volts.
When I add a "cap short" across the coil. the bulb light increases slightly and the volt meter rises to 2.56 volts - at the same time the rpm increases a tiny bit. which is why I am headed to the store to pick up more caps :-)
this method is not as sure as Bolt's amplified short, but I thought it might be worth exploring anyway - for its simplicity. it's definitely not as dramatic. leave no stone unturned.
As Explained for countless times over many years the road to ZPE = RF applicable tuning and resonance. Hector is right on the money!!
RLC  will lead to OU when the phase is taken to current node zero while the voltage is maximum. This can be done by matching the load to the o/p circuit in the form of critically adjusting L to create a phase shift or by adding and tuning more caps.  Dump caps will fill near instantly when the circuit has a large amount of VARS and the voltage is a maximum.  Tuning is usually extremely narrow band specific to load. However coil shorting creates broadband harmonics allow for much easier load matching. Its not just about creating more volts. Dump caps will fill even faster if the load is disconnected then reconnected between filling.  At the least consider switching the load off and on from the dump cap.    Although devices can be tuned using pure RLC you will find it MUCH easier to broadband it using shorting methods.
You should know there are systems about generating several hundreds of watts and even several KW;s using these principles........for a long time.   Go read my old posts on how gensets, RV's etc can and have been looped yet i was told there is no such thing! Im glad Romero released his muller looper i was almost sectioned and locked away in a nut house till now for breaking the laws of physics. Hahaha!
Good job people are slowly waking up 2012 is almost here.
scratchrobot
Quote from: bolt on June 07, 2011, 07:46:23 PM
Where and why is he hiding that part of his device?
Regards,
scratchrobot
bolt
sorry i don't understand that question.
scratchrobot
Quote from: bolt on June 07, 2011, 08:56:07 PM
No I am sorry, I read your post wrong. I thought you were talking about cap dumping and asked where are the parts to do that.
Regards,
scratchrobot
