0 Members and 51 Guests are viewing this topic.
crash_uni8
@anyone with AGW lock trouble
i just have my stator magnets on a shaft that is slight smaller diameter than the inner hole of the magnets.
but anyway i picked up some dry graphite for rc cars and getting AGW lock is very easy to achieve.
i am almost certain i could get AGW lock with a feather ;D
hope this info helped...
Omnibus
@Bruce_TPU,
I got the precision lubricator from RadioShack and tried it just for the heck of it. With it I could never get the stator to lock in AGW. It took me a while, when I reverted back to the Liquid Wrench  Lubricating and Penetrating Oil, to obtain a AGW lock.Now I'm good again. Try it. You can get it from the local hardware store or from the local WalMart three times cheaper.
MR t
Quote from: MeggerMan on February 11, 2008, 06:49:09 PM
Hey Dean,
I'm gonna get a caining for this one...I think I may be related to you, as I think my grandmothers maiden name was McGowan, first name Maisy.
Lived in Lossiemouth I think.
Probably need to check the family tree though.
@All,
Anyone notice that Harvey over on Fizzix forum is a lot like Al?...I could be wrong, but I have this funny feeling about it.
Rob
dean_mcgowan
Hey Dean,
@All,
Rob
Careful there champ you may have the naughty McGowan gene .. gets me in a lot of trouble  8)
I sometimes wonder if the McGowan tree is Sativa genus .. hmmm lets not go there
Cheers,
Dean
Bruce_TPU
Quote from: Omnibus on February 12, 2008, 11:51:56 AM
@Bruce_TPU,
Okay Omni,
Thanks.  I will pick some up today and try it.  Fingers are numb.  LOL
Try putting screws attracted to magnets in your stators, Omni.   See if there is a difference.
This is the only thing that I can see that Al is doing different from the rest of us.
Cheers,
Bruce
