The First TPU
Started by EMdevices, January 04, 2008, 05:41:48 PM
EMdevices
The first Toroidal Power Unit  [ TPU ]
by Steven Mark
http://video.google.com/videoplay?docid=-8435800732540412467&q=Steven+Marks&total=7656&start=0&num=10&so=0&type=search&plindex=8
[Here's a transcript of this first video.  If anybody has a better video then what's available on the internet please let us know. -EMdevices]
most devices are capable of generating electricity... and ...they're conversion devices, they?re not free energy devices ...they're ... they're not ?devices that can't be properly demonstrated.
these devices... take energy from the natural magnetic field of the earth, which has an inherent frequency... we basically tune into that...and ?take the energy that is readily available ....from the earth's magnetic field ? and produce electricity from it..
[takes out a voltage meter]
this is a voltage meter..  I'll use this voltmeter to demonstrate the power output of one of my devices....
[takes small TPU from box and places it on top of the table equipment]
this is the smallest device ....that I ever made.. one of the first devices ... this is put together with bailing wire... it is very very small...you can tell by the size of my hand and fingers that this device is very small... it doesn't contain any batteries capable of generating the amount of electricity that you're going to be witnessing here..
now I'm going to turn the device on ?through the use of this single measure... these wires travel directly to this meter right here......
[mumbling to himself while hooking up wires]....
ok...[clicks buttons on meter].....[starts lifting small magnet]...ok ... now ?I'm going to take this magnet  ? place this magnet right here
[places magnet on small toroid]
..the device is now putting out a constant ... consistent ?.62 volts ... 61.8 ? it will fluctuate back and forth ?.voltage wise ...
[removes magnet]
if you remove the magnet ?from the system ... the voltage automatically goes ...starts going down? there is a frequency pattern set up in here  ...and it takes a while to wind down similar to a jet turbine
[puts the magnet back on the toroid]
take the magnet ...put the magnet back within the device and immediately the voltage goes back up again ?61.6 ? 61.8
[lifts device in hands]
if you take this device ?and hold it in your hands.. it prod...it it vibrates ever so slightly right around 7.3 cycles per second ...and ...generates a little bit of heat ...during this conversion process...
[He turns device upside down]
if you take this device ?and for some unknown reason ...turn it upside down... immediately it stops producing electricity ?down now to 13 volts 12 volts ?it stops producing electricity
[He flips device back in normal position]
?.reverse it again ?.and immediately ? back up to 61.6 volts ...  I have no explanation for why that is
this is the smallest device that I have come up with so far... this device will produce 61.5 volts ...literally forever...the amount of current that it produces very.. varies ... at the present time it's 61.5 volts it puts out about ...25 watts ....the more current you draw from the device the more heat it generates....
now I'm going to show you a larger device I have ? also of similar construction...
very very cheaply put together ?there?s no mass circuitry involved with any of this stuff .... it's just the knowledge of the coils and how they interact with each other....
[talking to cameramen:  ?you can shut it off now and will go the other device?]
EMdevices
Seeing what Steven said about his first TPU is quite amazing.
1)Ã,  Takes energy from the MAGNETIC field of the earth.Ã,   Why not mention ELECTRIC field?
2)Ã,  The device TUNES to the right frequency of this earth magnetic field.Ã,  So it's a tuned device.
3)Ã,   Uses "bailing" wire, which to me says it's IRON wire
4)Ã,   Uses no "massÃ,  circuitry" just knowledge of the coils and how they interact with each other.Ã,  (note "with each other", why not with the magnetic field of the earth? hmmm?)
5)Ã,  The device depends on orientation,Ã,  so I believe it when he says it's tuned to the magnetic field of the earth. It's like an antenna, and antennas depend on orientation.
6)Ã,  Takes a magnet to start it
7)Ã,   He speaks of a jet turbine effect, he seems to understand it involves a "lag" or delay, maybe even rotation.
etc..
EMdevices
HopeForHumanity
I just made a connection. I haven't recalled Steven ever saying MY device. Only this device, the device, a device that I have. What if, using these habits of refering to the device, he isn't being honest to who made it. What if there is a secret engineer that we don't know about! Maybe he is just being made to say stuff. This would be the reason he couldn't give out anymore information. This would be the reason he wouldn't want to contact us. GUILT! It's all regret about claiming to be the inventor! With this situation, the government could have assassinated the real maker. We have been running in circles trying to figure out why this guy would just give up on a device that would change the world forever. I still think money wasn't the reason he gave up. He could have made even more money on selling the devices in his own buisness. Yes, this is a very large hypothesis, but think about it. There is no way he would just shut up about it.
Ron Paul is internet overunity: http://www.youtube.com/watch?v=vXnBZd4nyWk
WE MUST STOP THIS! Free energy is being surpressed because of it!
Grumpy
Compare this to the last video where he doesn't say it is tuned to the earth's mag field, and where he states that the energy comes form within the device itself.
Also, he turns on only two frequencies for the large ring.
...and they all have a similar thickness to the ring itself.
He's got the dragon in a "knot"...
        -Frank Edwards
amigo
I have been seeing these posts about TPU all over the forums here, but most of the time would ignore them because it didn't spark my interest. In any case I have watched the videos EMdevices referred to on Google Video to see what all the fuss is about and learn more about TPU and this "mysterious" Steven Mark fellow.
Sure thing the videos are of poor quality and to make a digression a bit, isn't that always the case? Just like the UFO videos, where things are either too far, too blurry or just bright lights in the sky. Well these TPU videos are right up there with the UFO ones, and there are lights in them, too. What's portrayed might be authentic and it does look impressive but then again isn't that always the case or the intent of the presenters?
Not passing a judgment here, I'm really not, but the only thing that stuck in my mind after watching the videos was that he said the unit uses Earth's magnetic field to draw it's power, and right there I felt it was a dead-end. If I recall correctly our scientists tell us that the Earth's magnetic field had reversed itself many times in the past and it is bound to happen again in the future. It is something, they say, that happens naturally and in cycles. Common sense tells me that this one, or any kind of device relying on a connection to the Earth's magnetic field is bound to failure and as such should be deemed unreliable.
Yes, it could be one of many backup alternative energy sources, if it can be reproduced and harnessed by everyone, yet I am not sure if anyone has thought about the Earth's magnetic field failure before since I did not read all the posts (way too many). I'm kind of a guy who worries that one morning we'll wake up and the gravity would reverse itself and everyone would fly up into the sky and out into the open space. Nothing is ever set in stone and taking things for granted might prove to be detrimental at the end...
