Gravity Motors = Free Energy
Started by Michel, July 16, 2005, 12:45:50 PM
_GonZo_
Quote from: Michel on March 31, 2006, 07:46:51 AM
Quote from: _GonZo_ on March 28, 2006, 07:10:47 PM
You can complicate the machine as much as you want, that will not make it work...
If it too is complicates for you, it is not my fault.
What I did is just simplify the machine and encrease where the problem is, in order to help in understanding  it better.
You can center better the weights, but the weights will always have to be able to flip a little in order to increase/decrease the volumes, and that little is enogh to put the machine in equilibrium and snd stop it due friction.
Just found this nice site, and here is a manny of this nice desings and why they do not work.
http://www.lhup.edu/~dsimanek/museum/themes/buoyant.htm
Tink
That is not what I made.
Like I said the weight should be in the middle as much as possible (near the axis), and in my case I used a bicycle wheelspoke to push a sort of cilinder out or in so an air bubble inside the lower arm (cilinder) will be pushed to the lowest "cilinder".
It is very simple if you see it and the lower "cilinder" went past the highest point (some 10 to 15 degrees) and wanted to go down again to be stopped in the end because the airbubble worked as a brake now.
That was a test with the weight blocked by a piece of wood to see what would happen and from that moment I knew I found it.
Leakage was a big problem so I made an other design which I thought would work much better but it did not work at all (shame that is).
The design that could have worked needed a mechanism to hold the weight down and only release the weight at top dead center so cycle starts again.
I promissed to make a drawing and I will but I have a family life too so have some patience.
If people want to make what i made and improve on it with a good functioning hold and release mechanism great!
Just be warned that it will take you far more time then you think.
The power output from this will not be high I think (just a few Watts at the most), but it is cool to see it keep on running till something wears out.
My interrest is mostly in the Steven Mark coil now because i think that has most merit (no moving parts, and lots of power).
(Edit)Oops, sorry Gonzo, I didn't read your post well enough I think.
What I said above was for the website you gave.
Synergy is the key to free energy.
_GonZo_
You meen something like this:
The buble is hold in the outside arms position mecanicaly until the load (black balls) arrive to them and then released to move to the center...
FreeEnergy
_GonZo_
I forgot to say that the tubes are filled with a fluid like water.
