My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
weri812
hello to all
S1r9a9m9 has released  a file on his transformer set up
can get a copy here http://www.4shared.com/file/54437779/9f61909b/s1r9a9m9_Transformer_Coil_Description.html
also on yahoo web sight   http://tech.groups.yahoo.com/group/WaterFuel1978/
thanks
wer
PUT YOUR MIND IN GEAR BEFORE  YOU PUT YOUR MOUTH IN MOTION
hydrocontrol
capacitor70
How to trigger plasma without diodes ?
1. Coil Black Wire carries high current, red wire low current for bulb
2. Bulb helps to conduct transformer. Without Bulb How you can make transformer work ?
3. Why we are using diodes, diodes prevent HV from going to battery side, we need spark
   at the tip of the spark plug and at the same time DC voltage across the tip. This is achived here with coil.
4. When HV gives spike to the coil, on coil secondery battery is connected which comes
   in series with HV induced in its coil, so the votage at the tip of spark plug is
   Bat + HV, creates plasma channel. No need of inverter, once plasma channel is created and discharge starts you need to disconnect battery
   from draining it completely. Sr1 is taking about some waveforms....
5. Once the plasma channel is created Battery current flows through plasma channel and
   bulb turns off, and HV coil is also in off state. This battery voltage is having large current, current is important
   for plasma blast this way it works. Plasma have infinity conductivity (zero resistance).
6. It dosent matter how much voltage is why we need voltage is to just to cover voltage drop of our diodes.
   I have taken trials with 175V DC and 315V DC both have nearly same effect.
Hear is pic of coil wiring... Make sure coil polarity (direction of turns)
happyvalley808
Capacitor70,
Are the second and third coil winding connected to the end of coil one??
Super God
We might need a better core than a nail to do the job.  For now I'm going to stick with cap70's circuit, because I know that's what works.  By the way, my diodes finally came in today!  Woo!
>9000
