My s1r9a9m9 replication!
Started by Super God, January 23, 2008, 07:26:21 PM
rfsimoes
Quote from: xbox hacker on October 28, 2008, 09:59:47 AM
@rfsimoes:
Have you tried to use HHO as the fuel with the plasma spark?
No I did not. I did not manage to build a efficient enough HHO tank.
In adition I think it is dangerous and It adds another complicated and variable to the system.
I don't see the advantage on using HHO in this.
rfsimoes
thermalenergy
Quote from: destino1320 on September 02, 2008, 02:36:41 AM
Greetings all
This is my first post here, and a have a few questions.
Here is a video of my set up
http://www.youtube.com/watch?v=nqSq3jVlMHA
so far we have built a pair of firestorm spark plugs and we have put together a combination of the Tero water explosion circuit and the JCBX circuit.
We cant get the engine to run however, so i am curious about a few things, especially from capacitor70 or s1r9a9m9
- what is the best air to water mixture
-what is the optimal way to bring the water into the engine
-what is the optimal timing of the engine
-what is the optimal voltage coming from the inverter, and end result through the diodes ( as diodes to consume some voltage, there is a voltage drop when using certain diodes)
- is there a good way to charge the water before bringing it in to the motor, with magnets, or ionization or joe cell etc
any more help or comments would be great
thanks for all the good work everyone!
Hi All,
this is my first post, so I wanted to read up to make sure somebody hadn't said the same thing already. The water feed to the sparkplug seems to fire best when it's atomized finely, so how about using an ultrasonic mist generator like is used around ponds and such? The circuitry of the ultrasonic generator could even be included as part of the sparkplug firing circuit. The generators I've seen have all used AC voltage, but since you're using an inverter already that's not a problem. The problem of how much air to mix with the water would be easier to solve with the mist than with liquid water. I think two separate power supplies, one DC, and one AC, are key to getting this working in an ICE. I also think the capacitors should be duplicated for each plug on a multi-cylinder engine, in order to give them more charging time between firings. I have a 3 cylinder Suzuki metro engine sitting in my garage that would be ideal for a plasma-fired, water powered conversion. The question remains, do I have to use it on mains current, or can I make it portable then get out and drive it?
Joel
capacitor70
This year we don't have winter season. Its raining in winter season and temperature is much much high :( 15 Centigrade more than previous years.
read this:
ORMES the Secret WATER FUEL CELL ingredient:
By: Jeremy William VanHaitsma
making of ORMES
http://www.youtube.com/watch?v=68jtnuMAa00
Have fun and happy, safe research....
Any one knows name of stone which is used in welding machine. when we drop water on it, it generates explosive gas ?
Gustav22
Quote from: capacitor70 on November 23, 2008, 10:22:13 AM
calcium carbide (CaC2)
http://en.wikipedia.org/wiki/Calcium_carbide
http://en.wikipedia.org/wiki/Carbide_lamp
money for rope
