optic sensor pulse motor
Started by jasonspinmaster, February 01, 2008, 02:53:35 PM
jasonspinmaster
i am building a pulse motor and i am using an optic sensor as the trigger. i am using a TIP 120 NPN Darlington transistor, from a 12 volt motor bike battery. i am getting a pulse but a small one. can any one help or does any one of any good but basic circuits. thanks all
jason compson
Groundloop
@Jasonspinmaster,
Attached is a simple circuit that uses a Hall sensor. You can probably use a opto
coupler instead of the Hall device. It is also possible to put a diode bridge over L1 to
harvest back emf power.
Groundloop.
RunningBare
Quote from: jasonspinmaster on February 01, 2008, 02:53:35 PM
jason compson
Need more information, whats the DC resistance of the coil?
hoptoad
jason compson
@jasonspinmaster
Try this thread : http://www.overunity.com/index.php/topic,3318.0/topicseen.html
Cheers
jasonspinmaster
the DC resistance of my coil is 003 ohms, i do not know if this sounds right or not. my coil is shaped like an ice cream cone, with a other wire wrapped around the primary coil for the back EMF (not connected )
