Thane Heins Perepiteia.
adlep
Quote from: LarryC on May 02, 2008, 06:10:36 PM
Quote from: mfred68 on May 02, 2008, 05:58:00 PM
Larry
you stated that your motor speeded up when you shorted out the HV coil, can you please tell me what happens if you place a normal 120v 60w filament lightbulb across the coil as a load instead of creating a dead short? dose it still speed up?
Sure, I'll try that tomorrow as we have a line of thunderstorms coming thru right now. I run my test outside under my house (up on pilings) in case the setup turns into a neo claymore mine thrower per Luc/Thane.
This is a great news Larry!
Please keep us informed.
OilBarren
Larry
I AM GOING TO ANSWER THAT FOR LARRY IYDM.
(BTW - WHAT IS THE RESISTANCE OF SAID LIGHT BULB?)
IF THE LIGHT BULB HAD A RESISTANCE OF 1 MEGA OHM - NOTHING WOULD HAPPEN - NO ACCELERATION.
IF THE LIGHT BULB HAD A RESISTANCE OF 1 OHM - THE SYSTEM WOULD ACCELERATE.
RESISTANCE VALUES BETWEEN I M OHM AND 1 OHM WILL VARY RATE OF ACCELERATION.
BACK TO YOU LARRY...
Thane
OilBarren
Hate to follow that show, but my humble setup has worked. Shorted it at 716 rpm at 107 volts and accelerated to 913 rpm at 105 volts. Larry
LARRY SORRY TO BE A "PB" BUT ARE THOSE WATTS?
Thane
LarryC
Quote from: OilBarren on May 02, 2008, 07:40:15 PM
Thane
Not a PB, you just pointed out a mistake. Yes, you are right. It is true watts from the wattmeter. Thanks, I'll modify the original.
Do you have the same wobble in the wheel that I stated?
Larry
OilBarren
QuoteAt Thane, great job on the new setup above
Luc
THANKS - I GOT ALL YOUR COILS WORKING TODAY WITH THE STEEL WHEEL.
I WILL SEND SOME PHOTOS TO JUSTME SO SHE CAN POST THEM.
THANKS JM
LARRY,
YES ALL THOSE WHEELS ARE THE SAME - I SAW ONE WORK REALLY WELL WHICH WAS BALANCED AND STRAIGHTENED - BUT THEN I BLEW IT UP UNFORTUNATELY.
Thane
