Peter Davey Heater
Started by storre, February 09, 2008, 11:00:32 AM
nul-points
Quote from: devrimogun on June 09, 2008, 07:51:26 AM
Sorry Nul. I thought Sandy would be a woman's name. You know - Grease for example.
"Saandy can't you see, I'm in misery. We made a start now we're apart there's nothing left for me......."
Anyway, next generation Sherlock then. Hows that?
no problem at all - it's a regular assumption!  :)   Sandy is also a Scottish nickname for Alexander - but i guess you'd need some Scottish connections to have heard that
but i appreciate your kind words - i'm actually working on an unrelated electrical anomaly & only came over here to see what ND was up to ;)  - i hope my comments have been some help & encouragement
ND has a major error in his assembly. Davey's has a curved handle and he boils his water using
his hand to put the device inside. The reason is probably to let the cups vibrate more efficiently.
His cups is nothing like Davey's cups and still 1.1COP? (Although fuse blows very soon).
ND will get there as soon as someone sends him bells of the size that is mentioned in the detailed
construction document :) and a handle :)
i agree that there is likely a whole area of freedom in replicating this device & any associated anomalies - i think ND has made a good start - as you say, COPs +/- 1.0 are very impressive for early tests!
i think vibration may be important - but probably not in the handle - i suspect more likely in the mounting of one of the mains electrodes, probably neutral
tests will show, hopefully, if the vibration can be just physical (with good continuous electrical connection) - or else if some vibration with the electrical connection is necessary (see my comments about possible mechanical SCR action, earlier)
i agree that Davey is probably hoping to hide the internals somewhat, but i think the key thing he hasn't mentioned publically is loose electrode mounting
however, he did make a point of mentioning that his heater wasn't approved early on due to safety concerns & i think it's highly likely that the casing also plays an important role in providing earth protection (it also 'contains' the water currently being heated, so this is an important feature too)
all the best
sandy
"...tell me more, tell me more, tell me more" (sorry - a little musical joke there)  ;)
devrimogun
Quote from: nul-points on June 09, 2008, 08:15:31 AM
Sandy,
Of course any input is valuable. I actually would like to transfer you from your anomaly
to this one. Here is my persuasive question : "Do you have any chances at all to get a COP of around
1 with your anomaly in your first try? :)
"well oh well oh well a-ha" (continuing the musical joke)
forest
I have an idea. Compare Davey device with any such electric heaters. Tha good key for searching among patents is : 'instantaneous electric heater'
I'm searching currently and have found 3 already, but all seems to be related to water flow inside device and to mix AC electrodes in a sandwich : live neutral live neutral live ... and so on..
That kind of separation is as stated most efficient to reduce current.davey is using it also in his heater patent
nul-points
hi Dev
> "Here is my persuasive question : "Do you have any chances at all to get a COP of around
1 with your anomaly in your first try?"
i'm currently seeing measured (Load Output Energy)/(Total Input Energy) ratios >= 1.1 and (Load + Control Energy)/(Total Input Energy) ratios >= 1.2 on the anomalies i'm investigating
my website below has details
what can you offer on Davey's heater?  ;)
seriously, though, i think my best contribution is to try & encourage folks to start testing, inspect results & then refine (like ND is doing) rather than think that everything has to be 'right' before you can make a start
this (heater) seems to be a very accessible area of experimentation which many people can get involved in both practically & theory-wise
there looks to be plenty of scope for members across the whole range of experience - as long as all safety aspects are carefully handled
it's not often you come across a process which seems to be crying out to have COP measurements taken straight off the bat
@forest
...just seen your latest post - i think the "live neutral live neutral live" electrode sandwich doesn't necessarily reduce current (that can always be varied by adjusting inter-electrode gap) - the real benefit of the 'sandwich' is to maximise water/electrode contact area, which therefore means that you can flow much more water past the heater per minute & still heat to the same level - ie. better suited to inline water-flow heaters than the static container type Davey is using as a 'kettle'
all the best
sandy
Doc Ringwood's Free Energy site  http://ringcomps.co.uk/doc
forest
What about this : http://en.wikipedia.org/wiki/Buzzer ?
"The word "buzzer" comes from the rasping noise that buzzers made when they were electromechanical devices, operated from stepped-down AC line voltage at 50 or 60 cycles."
Interesting
