My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
PYRAman
Thank you for this brilliant idea. I turned the sound off for one day now, allowing the pipe and sand to get cold, but after one day they are still hot, WITHOUT sound input.
The sound was on since 02.14. because I was afraid that I will lose the heating effect if I interrupt the process, but your question was legitimate so I decided to let the pipe cool down and turn the sound on again outside of the pyramid. But next day yhe pipe was still hot, so it can be only because of the pyramid, I guess, the special sound entered a state of resonance and now permanently receives the pyramid energy, without needing to be pumped with sound.
I was very surprised, the 'half-god' did not tell me that it will work also without sound input after a while.
I will make a sketch for you and put it on the board, because now I really don't want to take the pyramid apart just for taking pictures of every part, as I intended last time.
Quote from: neptune on February 20, 2008, 12:58:39 PM
@Pyraman.Here is the vital question that no one else has asked. Does your converter produce heat when used outside the pyramid?
PYRAman
Maybe this is the way how the quarz sand is pumped with sound in the Great Pyramid. I used loudspeakers  ;D
Quote from: sparks on February 21, 2008, 07:23:15 PM
    Could a pyramid act like a stethescope for the Earth?  Concentrating sound waves at the apex or causing them to resonate in chambers within the structure.  Maybe they even receive low frequency electrical waves and reflect them into standing wave fields within the structure.
mxt
The following info is not related to the heat generating pyramid, but it is interesting info about existing sharp pyramids.
I found that Alexander Golod, a scientist and now Director of a State Defense Enterprise in Moscow have built many sharp pyramids. Alexander had decided to build these pyramids because he believed that they would produce an energy field that could affect biological and non-biological objects. The largest and most recently built of the pyramids is located about 200 miles northwest of Moscow on Novorizhskoe Highway. It is 144 feet high and was completed in 1999. It weighs about 55 tons and cost over 1 million dollars to build. It is made of fiberglass. The Great Pyramid has a slope of about 52 degrees and these pyramids rise at about a 73-degree angle. The reason Alexander Golod chose this angle was based on experimental designs that also included the mathematical relationship called the Golden Section.
Soon after the construction of this pyramid near Moscow, botanists noticed extinct flowers starting to grow near it. It is unknown why this has happened and has mystified botanists.
One of the most interesting observations regarding these pyramids comes from Russian Air Force ?Radar? (or ?Locator? as they call it). The first indication that the pyramids were producing strange
atmospheric effects was when the 144 foot or largest pyramid was in the process of being built. The planned pyramid would be composed of 30 main layers or sections of fiberglass. At the completion of the 11th section, Air Force radar picked up an ion column coming right off the pyramid. This ion column was very large and in fact was over 1 mile high. As the pyramid construction continued, the ion column still remained.
Here is a book where I took this info. Very interesting book.:
http://rapidshare.com/files/76471079/0422.zip.html
password: tpp_overunity
Mx
mxt
Quote from: PYRAman on February 22, 2008, 11:10:42 AM
Here is what I found in the same book I posted above (THE COMPLETE PYRAMID SOURCEBOOK) Page 147:
"Dr. K. explains his discovery of this field (energy field) by first stating that the Great Pyramid was built to intentionally amplify basic energy fields of the Earth on a subatomic, quantum level. He calls these fields? inerton fields or waves and has measured them in model pyramids. He proposes that the Great Pyramid is a resonator of these fields produced by the earth. It would be a new physical field like the electromagnetic or gravitational field. This field is what affects the materials placed in the pyramids and caused the sharpening of the razor blades.
This inerton field is generated due to friction of moving elementary particles through space. Dr. K does not believe that space is emptiness like Einstein claims but is filled with a substrate, some kind of an ether, as scientists in the 19th century and early 20th had believed. There is more data recently to support the presence of this space substance. It is hypothesized that atoms of the earth vibrate and interact with the ether generating inerton waves. The Great Pyramid concentrates these waves and is saturated with them. These waves then cause the changes in the materials. Did the builders of the Great Pyramid know of these waves and built it as a resonator of them? He would like to measure this field in the Great Pyramid to prove his theory. Inerton waves spread in the resonator along two mainstream directions, which correspond to the East-West line and the vertical line."
Mx
sparks
   The US military did some work with extremely low frequency radio transmission.  They would string out antennae's sometimes miles long and oscillate full wave low frequency.  What is interesting is that they would receive on these carrier waves all sorts of pops and whistles coming out of the Earth.  Tesla also worked with low frequency high power waves.  If he wanted these waves to stay in one place to produce standing waves in the Earth crust, that could be used for power transmission,  he would have to use a frequency that would be resonant with whatever natural frequency was in the crust.  Now if the geoscientists are correct the molten core of the Earth is spinning.  This is a shitload of mass at high temperatures moving around just a few miles away.  Think of an Earth sized sphere of molten if not vaporized iron spinning around in place of the moon.   You sure as hell would get some radiant energy of some sort from it.  Now think of  having the same thing going on 30 miles down the road.  Definite sun burn potential.  Perhaps the Earth's energy flow is magnetosphere to polar regions to core vortex to surface to magnetosphere over and over.  The energy taking on the form of massive low frequency electromagnetic radiation.  Way below sound waves, but the em waves acting as carrier waves for sound or infra-red whatever.  Inerton carrier waves. :-X
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
