My heat generating pyramid - picture
Started by PYRAman, February 15, 2008, 04:21:08 AM
spacetrax
Hi@all,
nothing new here, somebody must have been inspired to do that long before Pyraman was  ::)
see here the 44 meter high pyramids from Russia
http://www.gizapyramid.com/russian/picture-tour1.htm
If it is the same thing we are talking about...
Cheers,
Spacetrax
Quote from: mxt on February 20, 2008, 04:02:31 AM
Quote from: PYRAman on February 15, 2008, 08:07:31 AM
And now some other good thing:  there is one suggestion that this "half-god" gave me for having a much better health and recovering from the schock waves that went through my body during the mental communication. I had to build another type of pyramid which does not contain the energy inside, like the Great Pyramid does, but spreads the energy around. This pyramid must be built only with non-metallic parts (glues including) its height must be at least twice the length of the base line (three foot) and it must be oriented to the geographic N-S line (not magnetic). I was told to chose a place inside the house and put the pyramid there and NOT MOVE IT anymore for a very long time. He said that the pyramid will build a strong field, bathing the whole house in it and preventing all inhabitants from becoming ill. I must say that I feel a lot fresher and stronger since this sharp pyramid is in place.
I suggest that all of us build such pyramids and place them inside our houses in the middle of a chamber, away from the walls.
I am sure, when every house will have such a sharp pyramid in it, most diseases will be history. If you have the skills to build the sharp pyramid, please show to all your friends how to do it. We must be all together!
But one should pay attention to the orientation, the geographic north will not be shown by a compass, but by the Polar Star, so it might be a little tricky to find the right direction inside of a house.
Good luck !
PYRAman
Can you give us some details on how to build this sharp pyramid?
I have seen the meditation pyramids (energy inside) which are only the frame.
Do we need to build:
1. Only the frame
2. The frame covered with the non-metallic material
3. The frame covered with the non-metallic material and filled with non-metallic material
Which of the sharp pyramid constructions makes the strongest energy field around it?
What material is best for this type of the pyramid?
Thanks for the information PYRAman and "half-god"!
Mx
pese
Quote from: magpower on February 19, 2008, 05:46:59 PM
Quote from: PYRAman on February 19, 2008, 04:58:10 AMThanks for getting back, but look at this http://www.ctglabs.com/electricity_from_pyramids.htm  is something that Thomas was doing but more advanced version. Can you get electricity from pyramids that the big question. Maybe the Half Gods could tell us more about this. Like to see more pictures and try this out. I guess a steel frame is not good.
Thks
Wayne
Forget this Pyramide.
This is not etheric radiation !!
Only RF Radiation from Computer!!. That will produced from keyboard enz. !!
Phramide is only "antenna" to receive this RF and Low frequencies. Ist only "static" voltages . NO any POWER !!! behind this.
You can try with 20cm wire instead pyramide.
You can find more "Mystery" schematics in ctglabs ... (and others)
Pese
neptune
@Pyraman.Here is the vital question that no one else has asked. Does your converter produce heat when used outside the pyramid?
sparks
    Could a pyramid act like a stethescope for the Earth?  Concentrating sound waves at the apex or causing them to resonate in chambers within the structure.  Maybe they even receive low frequency electrical waves and reflect them into standing wave fields within the structure.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
PYRAman
This pyramid is built on a wooden frame and covered with any non-metallic cover you can provide.
Good luck !
PYRAman
1. Only the frame
Mx
