IS the TPU a Small Magnifying Transmitter?
Started by starcruiser, February 16, 2008, 06:52:00 PM
starcruiser
I have been looking for ideas and theories on how the TPU generates the power SM shows. Several of Teslas' patents touch on this as well as a few others. They always seem to lack all the specifications in order to build it, or are rather vague in some way. Several people have mentioned that it looks like it may be a modified Tesla coil. Others think it looks like the Gunderson device. I am sure others see something different.
I do know that a lot of the devices seem to share a common thread or idea.
My take on the TPU has brought me to see a similarity to a Magnifying Transmitter. SM thru Mannix has stated that it is basically coils of wire and how they are arranged. The recent MIT project showing the large resonator coils caught my attention and lead me to ponder what would happen if there were 3 or 4 coils/resonators (copper wire was shown could use bailing wire perhaps??) arranged in a circular shape one feeding the next in line.
The source to start this off would be a small oscillator that is inductively coupled to one of the resonators, magnets would be used to enhance the coupling between the resonators. The power take off would be an inductively coupled coil off one of the other resonators, take a closer look at the open TPU video, it has 18Ga stranded wire wrapped on it, is the is the resonator or the power tap? One of the legs houses a small torrid coil and another a 9v battery. The spaces between coils is holding square black things, perhaps ferrite magnets? The theory for the MT says to offset the signal source to avoid coupling to the power tap, so if the small torrid is part of the oscillator and is below one of the resonator coils this would effectively offset it from the power tap coil right? So lessened inductive coupling.
Now here is the beauty, the magnets may be acting as magnetic diode of sorts pushing the pulses in one direction more or is it just assisting the coupling of the coils? Maybe both.
I have not yet tried this but will do so shortly, my time is constrained and I will not be able to get to to building this right away but I wanted to get this out to the masses for feedback.
I have attached a PDF showing the idea, for an oscillator you could use your favorite design or use EM's which can be found in the Mini Tesla thread here on OU. The form for the coils is rather easy, can use some plastic tubing or plexiglass if you want to make it look like the open TPU. Some of you may already have the required materials on hand (no cost but your time). The real trick is to match the coils/resonators and make sure you can control the oscillator since if I am right the coils will self feed (circular feedback loop) and the oscillator will continue to kick the pulse around the circle. The magnetic field is required to provide the starting bias for the coils. All of these materials will make a rather light device, similar in weight to the TPU as it was claimed.
Now for another take on this idea, it is possible that the TPU itself was nothing more than a receiver for the power that was transmitted from somewhere close by, the TPU was nothing more than a resonator coil with its power tap/coil and the magnet may have just allowed it to connect to the power source. If this was the case then it was a scam of sorts and SM just built Tesla's MT in miniature. The only way I see to prove it one way or the other is to build the unit and try both possibilities. If you recall marco did build a similar device that did work on these principles.
I have also attached the MIT article for reference as well as the Molina doc. All are kind of related.
I could be full of Sh*t but who knows? Lets see...
Regards,
Carl
turbo
Hey Carl :)
I truly think we are dealing with something entirely diffrent in the SM Show.
M.
starcruiser
marco,
Could be but I am exploring all possibilities. I really do think SM has not provided us all the info and may have provided incorrect info along with the correct thus confusing us. Also mannix was the conduit and may have not provided all the info either. Now I am not saying he has done this intentionally, but everyone interprets info in their own way. Was SM's deception intentional, who knows, so we need to explore all. I find it interesting that all of these types of devices have similarities to one another don't you?
I am going to follow my current concept to see what it provides. I do believe we all need to follow our ideas to see if they bear any fruit and get us closer to the end goal right?
Regards,
Carl
Frederic2k1
I don't believe that SM has only build Tesla's Magnifying Transmitter, because in one video SM went outside of his house und the TPU does still function.
I think in the magnifying transmitter the coils must have good arranged in the room... You can't take one coil off its position without losing transmission.
Moreover, why should SM fake it ? Definitely not for his personal fun...
AhuraMazda
@Starcruiser,
I am going to get heretical for a moment and say forget SM and even Tesla for a minute. If you were a hunter and going to hunt a
deer you would use very different technique and bullets and timing etc as oppsed to if you went to kill a rabbit!.
Get fixed in your mind what is this source of energy that you are going to tap into? Just winding wires and applying different
frequencies etc will only take you where all these TPU threads are.
Once you have identified the source of your energy, then use the knowledge gained from Tesla or any other VERIFIABLE source to help you capture it. You may decide on your own that a hexagonal or even a cubical structure might provide a better frame work for your energy device.
God luck
AM
P.S. I am not a guru so, references to alternate shapes for the energy converter is just an encouragement to make you think outside the box.
