Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
sm0ky2
For those that "actually" give an f enough to do a little math:
The Ni/Cu/Ni coating +4 + (-1) = +3
we can ignore the inner junction
synchro1
Quote from: Magluvin on December 02, 2019, 12:35:40 AM
Hmm. Seems interesting to try and see if there would be any impedance of a pulse through a stack of neos, one polarity then the other. Might think the fields of the mags would affect it somehow. ???
Mags
Mags,
The Tesla series bifilar test shows the higher rate the coil accepts a charge is due to it's innate capacitance. This dielectric field energy carries the power of "Impulse Magnitization" to ferrite. This "dielectric pulse" through the Neo magnet, not the current, is retarded or helped by the polarity.
Faced one way the polarized radiant energy strengthens the isometric symmetry of the magnet domains, the other way causes disarray demagnetizing and loss of strength. The Neo magnet acts as a conductor to normal electric current with equal resistance or impedance with either polarity. However; Not only does the correct polarity radiant pulse strengthen the magnet, the permanent Neo field also conversely reinforces the static field of the pulse in transit.
Your bifilar pulse test bed would probably adapt well to this test with little effort if it's still around. It kills the magnet to shock it the wrong way. One pulse magnetizes the ferrite; The second pulse is magnetized by the field of the permanent magnet, and reinforced in strength.
Done correctly, this test would act as definitive proof and confirmation of Overunity. Two capacitors and bifilar pancakes a stack of neo's between, a pulse circuit and an "H" bridge. This bifilar sandwiched Neo disc and caps could shuttle the amplified charge back and forth and run a load perpetually.
It would only take one concrete test to prove the feasibility of this kind of solid state free energy generator.
Naturally, anyone who follows my threads knows this is the working principle behind Captain Coler's apparatus and Schappler's UFO motor for the Nazi Luftwaffe.
Dr. Stiffler shows a blue capacitor sandwiched by a stack of Neo discs. He has a 13.5 Mhz oscillator frequency probe not attached to anything but capacitively in adjacency to a bank of LED's with a plate connected to the back. Stiffer illuminates the LED bank with no electrical input. The capacitance is vibrating the magnet field and generating the current inside the light emitting diode.
synchro1
Stiffer is oscillating his stack of Neo magnets capacitor sandwich with an A.C. capacitance frequency at 13.5 Mhz. The "H" bridge is an analog version of the same circuit that can isolate a single pulse.
The magnets amplify the capacitence or dielectric field, not the magnetic. Power is stored in the static field and transformed to electricity by discharge. The generated capacitance of Stiffler's magnet sandwich is discharged into electricity inside the LED.
This design MEG should be able to generate power with no input the same way at any frequency.
Looping Stiffler's magnet sandwich with a crystal oscillator would equal OU infinity.
synchro1
Lidmotor's 13.56 Mhz oscillating static field is blind to his wireless receiver:
https://www.youtube.com/watch?v=PqsVQPLXi3E
The capacitor in Lidmotor's Stiifler Neo stack test failed to work because the dielectric insulator was not of HV value. The wave length between the charge plates has to match the oscillating frequency of the crystal. That additional magnet amplification would multiply the output of Lidmotor's coil resonator.
synchro1
Theoria shows an incredible photograph of the static field inside the core of a Neo tube magnet:
https://www.youtube.com/watch?v=AmuxvP96ipk
