Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
synchro1
Dr. Stiffer showing modulation of the magnet's dielectric field in figure 4; The field is visible inside the magnet core in Theoria's video above: This is the "Static Field" Dr. Stiffler is modulating: There is no electrical input into Stiffler's circuit. It costs nothing to raise the potential by modulating the static field. It costs power to move the magnetic. Collarary of Faraday!
SFM raises voltage with zero input, magnetic motion generates amperage in proportion to force.
                                                           SFM - Static Field Modulation.
https://www.youtube.com/watch?v=FFhRx8PgK8c
synchro1
The challenge remains for Magluvin to perform a "Single static field magnet pulse test for gain".
Mags's testbed for his bifilar pulse test is ideal for the magnet amplification one. The permanent magnet and the Tesla bifilar coil both share capacitance and magnetic field. We are only concerned with modulating the "Static Field" of the permanent magnet with the bifilar pulse, not the magnetic.
The physics of the "Static Field" is counter intuitive. We hear terms such as superluminal, multi dimensional,
ether, time reversal etc. to describe longitudinal wave consequences. The voltage in the static field of the magnet core is as inexhaustible as the magnetisem is in the magnet.
smOkey2 says ferrite chokes conform to Mag Amp laws. This is Einstien to Newton.
synchro1
The static field in the magnet core may act as a pathway to outer worlds, just like our travel to space. The static field is connected to everything everywhere at any instant in time. Tuning the resonant frequency of the Twin Helix LC tank of our bodies may allow us to teleport through magnet cores to multi universes. Swami says the multi universes are a genetic memory because our local one has already permutated through the cycles.
My "Synchro coil" was a diametric tube with a bifilar solenoid coil and a capacitor and diode. These componants acted as a "Quantum receiver", just like Dr. Stiffler's (FWBR) and spontaneously generated power.
Placing a stationary magnet next to a coil generates no power; However, the "Synchro coil" does! Static field modulation inside the magnet core from the LC tank resonance generates current in this circuit while stationary.
I believe the diametric tube magnet has a more focused static core field then a solid disc. Really like a ring magnet.
synchro1
                                                        THE SUPERLUMINAL RADIO
It occurred to me that two identical "Synchro coils" would act as self charging transmitters and receivers for longitudinal wave communication. I wonder what the range of these self powering "Scaler Wave" radios would be with transmission speeds faster then light?
Suddenly discharging the capacitor in one set should blink an LED in the receiver set over any distance instantly as far as perhaps between Earth and Mars. This would reduce transmission time from up to 24 minutes to immediately!
Raycathode
Quote from: synchro1 on December 04, 2019, 06:24:22 AM
It occurred to me that two identical "Synchro coils" would act as self-charging transmitters and receivers for longitudinal wave communication. I wonder what the range of these self-powering "Scalar Wave" radios would be with transmission speeds faster than light?
Suddenly discharging the capacitor in one set should blink an LED in the receiver set over any distance instantly as far as perhaps between Earth and Mars. This would reduce the transmission time from up to 24 minutes to immediately!
Are you sure you know what you're talking about here as the above statment is a contradiction and others are misleading, don't you know the difference in there properties
