Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
synchro1
Ringing the static magnet core of one magnet with a potential clapper, would ring the core of a twin magnet at the same level anywhere.
A string between two tin cans in hyper space.
I believe this is an original thought.
synchro1
Take two tube magnets, shock one with a snap discharge and place DMM electrodes on the other and see if the shock from the first tube magnet bumps the voltage on the second magnet from the static field effect.
This would be a historical first equal to Heinnrich Hertz's classic experiment on the transmission of EM waves, only longitudinal static magnet core. We are not moving iron filings from the magnet wave, but bumping a needle on a voltage reader from the dielectric.
The next step would be to place the receiver magnet on the Moon and measure the speed of transmission. A superluminal scaler wave radio and receiver for instant transmission of data and power to Outer Space. Voila!
sm0ky2
Take one magnet
And discharge sparks to it for long enough
and its' magnetism will be depleted.
synchro1
Quote from: sm0ky2 on December 04, 2019, 11:59:40 PM
Take one magnet
@smOky2,
Running electrical current through the magnet material as a conductor is far different from modulating the "Static Field". Remember: "There are two planes of energy in the magnet"! They balance one another.
Neo magnet cores are wed in Hyperspace. The power of the static field is the speed of light squared in potential, no matter what the spatial distance between the magnets, the cores are bonded in the 5th dimension.
We can modulate this counter space continuum. Voltage is not electricity. We can raise and lower the voltage potential of the static field in the magnet core with no electricity passing through the magnet material. Discharging a spark is simply a quick and dirty way to impact the dielectric field. The final static field resonance would be generated by a 13.56 Mhz crystal.
This would act as a Superluminal trunk line for power and communication; Both the digital and sine wave. Instant watts to load. We need to resonate the static magnet core fields at the same frequency, then we can modulate the potential across the "Hyperdimensional Channel". Static Field Resonance would create a state of "Quantum entanglement" between the magnet core fields.
A tube magnet with a crystal attached would portal all information and power wirelessly from outside the space time continuum. Two static magnet core fields in resonance are entangled in the Quanta, and are an identical state. No longer two separate events but the same event.
synchro1
Twin quantum receivers could transmit and receive an AM broadcast signal through the static field link between the two magnet cores. The "Synchro Coil" tank frequency would modulate the static fields in the A.M. bandwidth.
I believe Dr. Dollard replicated a 1/20 scale Wardenclyff that transmitted an A,M signal by scaler wave.
This would be relativly simple to do but represent a milestone in history!
