Electricity Amplification by Neo Magnet
Started by gotoluc, February 17, 2008, 12:27:13 AM
This topic died? I was just playing around with a super crude setup (using fingers to hold wires on battery  :P) and was amazed of the big sparks that were caused on this old rusted speaker magnet. I scraped the wire along the surface of the magnet. I used 2x1.5V batteries and also put my hands on the spark but I felt nothing not even the slightest tingle (probably too weak batteries).
This is a fun experiment nonetheless.
gotoluc
Quote from: broli on July 26, 2008, 06:10:22 AM
HI broli, thanks for looking at this topic. It is not a dead topic. It's just we have not found a way to get more energy out than in yet, so people loose interest.
Luc
fk462
try lowering the voltage and current to tune it to the transformer and see what happens
Thedane
Just saw this interesting topic.
If my theory is correct the following explains what happens:
Magnetism is the Atoms ability to send out matter/antimatter streams who orients nearby Atoms North/South particles magnetic fields.
Magnetism from a permanent magnet is similar to DC voltage, however the difference is that there is no pressure difference of matter/antimatter fields in space so no current can flow.
Moving a magnet over a conductor will cause a "tidalwave" of locally uniform oriented matter/antimatter streams in the conductor, and hence a difference of pressure throughout the conductor = a current flows.
In essense the Neo magnet works as a dead DC battery and by pulsing the wire the matter/antimatter streams around the magnet the driving voltage to the coil is increased.
I've started a topic here about my theory:
http://www.overunity.com/index.php/topic,5549.0.html
Have a great day  ;D
FreeEnergyInfo
Quote from: xee on June 27, 2008, 02:49:41 PM
@ gotoluc,
While I was doing drawings, I also made this one. Hydrogen Tap found that if he ran enough current through the neo magnets they would no longer be conductive but would intermittently generate large sparks when connected to a 12 volt battery. If you can get your magnets to become nonconductive then you should be able to build the following circuit and would get sparks without any mechanical moving of the wire. You may have to reverse the battery polarity.
oho...
vau...
