Tri-Force Magnets - Finally shown to be OU?
Started by couldbe, February 20, 2008, 08:45:25 AM
Omnibus
@smOky2,
If what you?re saying is true and there?s indeed 25% greater energy out, exiting the set of stations, than in (that is, the energy to overcome the repulsion barrier at the entrance) then it is OU and we have made it even in the horizontal variant. That has to be demonstrated experimentally, though, because it isn?t at all evident theoretically in this case.
FreeEnergy
can't you have something that mechanically or electronically  flips the magnetic poles from the swinging pendulum's torque (better use a Milkovic system http://www.overunity.com/index.php/topic,1763.0/topicseen.html)? this torque somehow mechanically or electronically  flips the magnet's poles for every swing that goes in/out.
just a thought.
peace
sm0ky2
Quote from: Omnibus on February 24, 2008, 04:33:54 PM
@smOky2,
thats somewhat is a mosgnomer.. there is not always "25% more energy out".
there is 25% more energy generated while transversing the gates. - meaning, sometimes this must be extracted inbetween the entrance and exit of the gates -
i.e.- by work, such as when Clanzer's set-up transported the firetruck through the gates.
the repulsion force at the gate exit is identicle to the force at the entrance, on a "balanced" gate..
Rusty_Springs
Hi sm0ky2
I felt my trigate was OU but I wouldn't say it until it was confirmed by other sources and your maths sound good, I would like to say that to make a magnet move along a plan you need repultion, magnets move from repultion to attraction if you remove the repultion the magnet has nowhere to go and will just sit there, the best you can do is move the repultion so its easier for the magnet comming in which I have done with the extended magnets, this give a bigger area to come into and has more kick going out.
I'm not saying a working motor will come from this but if you can enter the extended gate at the dead zone this takes you past the repultion and you will travel along the gate and kick out a working motor maybe like this, you have a rotor arm with a bearing in the centre at each end you have a bar magnet standing upright as the stator you have two Trigate setup so the rotor magnets come in at the dead zone and they are opposite each other now the rotor arm is attract at both sides by the Trigate moves along the Trigate then kicks out crosses the air gap and again is attracted in by the Trigate opposite and the rotation continues no repultion comming in because your moving in at the dead zone and repultion going out to cross the air gap.
I havn't tested this but in theory it looks good, I have one rotor and two Trigates because I always find with magnets that less is alway better.
Take Care All
Graham
FreeEnergy
if anyone knows a way a roller can also role sideways let me know or show me an example.
because if we can have the roller role up a ramp then role sideways it can go back to its initial starting zero point.
