free to air energy
Started by samzoelisa, February 24, 2008, 02:08:31 PM
nightlife
Koen1, I moved this to a new thread so I wouldn't take the attention away from this persons thread as I have with other threads.
As far as the movement goes, it would have to be set up on a tension coil to keep tension on the wires attached to the coil. the tension coil would then have to be utilized to capture the energy it would produce. Every moving part and every vibration has to be utilized just to achieve close to 100% efficiency within the design. That in it's self is a trick do to vibrations being able to flow thru anything depending on it's vibrancy. Everything must stay tight with very little clearance and or escape routes for the vibrations to escape from the designs resistance.
When a vibration is created, it is most vibrant at the precise point of resistance made and it diminishes from then on. The trick is to use that vibration to create another more vibrant vibration. That is why we need to use magnets.
I still have a lot to learn here as well as I do with circuitry. I am just not educated enough in these fields to be even trying to attempt this. My lack of circuitry education is really a major fall back for me and I am finding this out as I try build something. It is trying me nuts. LOL
I don't have a clue about the TPU in which I think you are talking about. That is way beyond my level of education on circuitry. I am full of concepts but I am finding that I have a lot to learn as far as what to use to build them. I am finding that certain gauged wires are needed for certain strengths of magnets as well as for the certain speeds of the magnets movement to achieve the best results.
I moved my idiotic concepts to http://www.overunity.com/index.php/topic,4221.0.html
