free to air energy
Started by samzoelisa, February 24, 2008, 02:08:31 PM
pese
Es ist nicht m?glich mit einem abgestimmten Antennenkreis
?berall solche Leistungen zu ziehen.
Ich lebte (1950) 1km von einem Mittelwellensender 900 khz. (Detedtor-Empf?nger)
Es hat gen?gt f?r einen kleinen Lautsprecher.
Direkt am Sender habe ich kleine Lampe zum leuchten gebracht.
In Berlin haben Gartenvereine Ihre G?rten beleuchtet mit Deutschlanfunk , der dort direkt angrenzte.
Das ist verboten wordenm weil die Leistung dem Sender "entnommen" wird.
Die Feldst?rke eine Senders (Leistung) sinkt quatratisch mit der Entfernung.
Auf diese Art gibt es NICHTS "frei" zu nehmen !!
Pese
It is not possible with a concerted antenna circle
Such services everywhere.
I lived  (1950)
1km from a  AM Transmitter 900khz.
It suffices for a small speaker. (with crystal-radio)
Directly on the transmitter, I have little lamp to glow.
In Berlin, garden clubs your gardens illuminated with Deutschlanfunk, there angrenzte directly.
That is forbidden wordenm because the performance of the channel "removed".
The field strength of a transmitter (power) quatratisch decreases with the distance.
In this way, there is nothing "free" to take!
Pese
nightlife
pese, I am not talking about the actual signals from the stations, I am talking about the static.
Here is another way. Take the coil and put a long magnet in the middle of it. The coil will travel up and down the magnet depending on the polarity. Then you place that configuration inside a coil that is the same length of the magnet. As the voice coil moves back and fourth, it will create a electrical current in the outer coil that can be used as a power source.
Koen1
and what makes the coil move then? If you tap all the electrical fluctuations in the coils,
there should not really be much movement left of any kind...
and you're saying you can rectify pure "static" noise into usable energy levels
using a simple high-ohmic crystal detector?
That's quite odd... as crystal radios only work due to the fact that the radio
signals are AM, and it is this amplitude difference that causes the voice signal
output...
Does your "static" circuit also work in a faraday cage? After all, you may be picking
up "static", but you can't really be sure that is not powered by radio transmitters
somewhere down the line, unless you shield it...
nightlife
Koen1, good questions and I will have to build one first to find out. I have found out that there are other things that can be used in the place of a crystal. I will do some test to find out.
As far as the faraday cage, it should not work because of it requiring a signal unless the signal is in the cage with it. Meaning that a antenna was placed out side of the cage and then attached to the radio.
To hear anything out of a voice coil requires the voice coil to move. It is used to move a cone to make sound but you take the cone away and it still moves the coil. The cone keeps the coil from coming completely away from the magnet. The static should come from any vibrations within the frequency level.
It will make for a good experiment.
nightlife
My theory and concept works people.
By moving one coil back and fourth passed a stationary magnetic, you produce power and that power can then be absorbed by a coil that surrounds the two. The power absorbed is much more powerful then the power used pulse the inner coil to get it to create movement. This new, more powerful source, then can be used to power it's self and yet have power left to power something else. Using the back EMF off the pulsing coil would help keep it cool which would add to it's efficiency.
There you go people, the answer to over unity and free power.
