free to air energy
Started by samzoelisa, February 24, 2008, 02:08:31 PM
nightlife
We can use radio waves for producing power. Crystal radios are a prime example as well as a good way to start. The crystal radio uses no out side power source nor does it use battery?s. It does produce enough energy to fire a voice coil. That voice coils movement can be utilized to create electricity. Not only that, but it can also be used to get rid of gates with in permanent magnet motors by using the magnetic field that it creates.
Think about it and you should understand what I am talking about.
nightlife
This next video shows one and note the static it has. That is what you need to pulse to get the permanent magnet motors passed the sticky points.
When the static is present, it creates a magnetic field in a voice coil, Due to static being continuous, you are supplied with a constant current to the voice coil. Activate that current just after center of a magnets polarity. You will then get a repelling effect. the coil and magnets polarity's that face each other will have to be matched, meaning both would have to be a north or a south.
http://www.youtube.com/watch?v=GkdYBIS-NSI&feature=related
nightlife
Not only can a voice coil be used to repell, but if the polarity is swtched at the right times, they can also be used to attract and repel. This would give the motor more torque.
nightlife
The size of the antenna coil would determine the power that can be achieved as well as linking them together with others. Linking them one way gives you voltage and another gives you amperage.
I think I have done it. This maybe what I have been searching for.
Thank you for starting this forum and letting me get involved.
