Nightlifes wacked out ideas.
Started by nightlife, March 05, 2008, 12:32:42 AM
Formula1
Quote from: nightlife on March 07, 2008, 07:29:40 PM
I found that using a vibrant vibrating coil works better then a speaker. Back massager, foot massager and even a  toy's vibration set up will work.
Put any of them on a surface and see how the whole surface will vibrate and then lay magnets on is and see how they will vibrate. I am finding that the coil windings are the real trick as well as the circuitry. I am not educated with either and that is my hold up.
You, sir, are me in another body...
-Uneducated... but still giving this a shot........
nightlife
Formula1, well at least now I dont feel like I am alone. LOL
I am going to Walmart to see if I can buy a few of those lights just so I can take them apart and try to use the parts they use.
I post what I find.
nightlife
I posted my test results of the flashlight at http://www.overunity.com/index.php/topic,4241.0.html
It is not very efficient compared to what the wind belt is said to be. I have found good results with using a vibrating coil but I am not 100% sure because I don?t have the circuitry that is needed to get a more positive result. I now have the flashlight and I will try and utilize it for my needs as well as for upscale modification to my design provided the flashlights circuitry will hold up to what I believe will be more power..
nightlife
Based on the results of the flashlight, it would have to be multiplied by 40 times it size to get 130volts at 7.2 amps. That means it would have to take a magnet 5ft X 7.78ft
With the wind belt, it would have to take 30 times it magnet size, provided it has a output of 4.5 volts and assuming it has at least .18 amps of the 4.5 volts, to produce 135 volts at 5.4 amps. That would mean the magnet would have to be about 1.25ft X 2.5ft.
That is a very large difference in efficiency making the wind belt set up a much better design provided it puts out what it is said to put out and if my assumption of the amps are right.
It would take much less power to vibrate a magnet that is 1.25ft X 2.5ft then it would to move a magnet that is 5ft X 7.78ft.
nightlife
Another thing is that the size of area needed for the actions to take place. The wind belts action area is very small compared to the flashlights action area.
