Simple PWM
Started by rtsurfer, March 06, 2008, 09:22:34 PM
ramset
RTS  according to Smack as I recall with his soup recipe your readings are not lining up   of course all water is different  have you started process with distilled water or tap [unknown] water sorry I have to go look at some machines will be back later   Chet
Thanks Grandma
rtsurfer
Quote from: ramset on March 09, 2008, 11:04:37 AM
The electrolyte was way too strong. I diluted it a ton and It can down. At the moment I am using tap water. This is not an exact replica of smacks just used his as a model. My container is stainless steel and grounded. It is not my final design but just the beginning.
rtsurfer
Well I have had the cell running in the 2002 Blazer for a week. I went from 18-18.5mpg to 20.65mpg without the EFIE mod. This is on a 4.3liter engine. My first container had allot of problems, Vacuum leaks, shorts and finally the plastic lid cracked. I went with a PVC container that is air tight. It stands about 14? height and 4? diameter. I am working on new plates to put into it. 12? height with 10 total plates. Spaced at .09 apart. I also vented the HHO line into the PCV vacuum line. There is a very strong vacuum there but once I had a seal on the HHO container everything has been much better. Will give a new update when these plates are done with pics.
pese
Quote from: ramset on March 08, 2008, 11:41:02 AM
RTS sorry I was Interrupted by some visitors I;m not being a wise guy  just trying to understand  mainly because Im not sure how the amp gauge will work in series  with a pulsing device  Chet
Can you use "controllers from (old) battery drilling machines ?
Somes work up to 10 Amp  12 18 and 24 volts.
I work with tham for other app?ications very fine , cheap , small and iniversal usefull
Pese
helmut
Quote from: pese on March 16, 2008, 06:07:13 AM
Pese
Hi Gustav
Thats thrue,I use such Motor and Controler to adjust the satellite dish
helmut
