Simple PWM
Started by rtsurfer, March 06, 2008, 09:22:34 PM
rtsurfer
Well I have used the distilled water and?.
No more brown crap floating around the plates Now that is a plus.
Before I added any baking soda I got less then an amp drain (.60) Good.
But then it got me thinking this system may have been better? Why
Well first I had a Positive negative arrangement for 11 plates (5positive and 6negative) with negative on the outside. Problem was I had 19amp cold with no baking soda  using tap water. I kick myself now for not trying the distilled water to find out where I would have been. Before I tore it apart and cut down on the positive plates.
Oh well?. Lesson learned
ramset
 RTS WELL the good side is you won't do that again   please keep posting your results and questions thanx  Chet PS if you could hold off on the computer control device for a while it would be good
Thanks Grandma
rtsurfer
Quote from: ramset on March 16, 2008, 10:30:30 PM
Got that right. :-\
rtsurfer
So here is what I have. THis thing is power hungry. Any thoughts?
I used distilled water/bking soda cold 9amps light hho production. As it warms up more and more production. Also more and more amps. I just blew another 30amp fuse on the way to work.
So should I boil the distilled water first. Get it hot. then add baking soda to get to 15-20amps? Will it stop there?
Would a heater work in conjuction with the HHO cell?
strapped9
boil distilled water?
     heating it to the cells max temp and adding electrolyte is fine but it will take ages to get your cell that hot in the car. since itll start at just a couple amp. sure seems like electronic regulation would make more sense here.
