My totally Baked IDEA
Started by bigfatpothead, March 14, 2008, 03:24:21 PM
NerzhDishual
Hi BigFatPotHead,
Thanks for your reply.
28 * 1.61 =/=45. Sounds very good!
And, BTW, not too good to be true, IMHO, as a relative of mine is claiming more but with a much more elaborated (and expensive) device.
http://freenrg.info/UTOPIATECH/PROCES_VERBAL_2.pdf
(Process-server's affidavit in French).
Best
Nolite mittere margaritas ante porcos.
bigfatpothead
I am trying to find the stainless steel to build an electrolyzer big enough to run a 4 cylinder car, if not comepletely, then enough to where I am getting 80 MPG or better.
z.monkey
Howdy All,
About the electromagnetic reciprocating engine had you thought about a rail gun driver?
http://www.amazing1.com/electric-guns.htm
With a rail gun driver you wouldn't need to glue an electromagnet to the top of the cylinder.  The rail gun will push any kind of ferrous metal.  You would have to generate a high voltage and store it it high voltage caps.  Then when the piston reaches the break over point you trigger a pulse.  Bam! that hits the piston, and your high voltage generator recharges the high voltage caps in anticipation of the next break over point.  You probably would not get very get many RPM's out of the motor to start, but further experimenting could evolve a system which actually begins to compete with gas motors.  He he he,,,,
Blessed Be Brothers...
Goodwill to All, for All is One!
bigfatpothead
I would like to keep this thread about my magnetic motor idea, and save the hho talk for it's related forum
thanks
FatBird
