Complete information on working SM style device.
Started by spherics, March 17, 2008, 12:03:53 AM
Bulgar
Last I tried it and got the best results:
http://mazeto.net/index.php?action=dlattach;topic=739.0;attach=16162;image
The 4 coils are of such a configuration. Do not get anything abnormal except higher voltage in a collector ~ 50V and a few milliamperes current.
http://mazeto.net/index.php?action=dlattach;topic=739.0;attach=16154;image
90% of the trials conducted by the bifilar winding and iron yoke delay.
sigma16 @ This is not going to happen with a permanent magnet?
For model 15 cm in height what should be the proportion of approximately? Current in the coil what should be? Okay be limited by the resistor?
Maybe Ill try your idea first, would take time to build a high-frequency circuit. /ZTX415 ..../
These days, read mise dealing with something simple. I will experiment with a Tesla transformer. With bifilar primary/secondary and any lag ciruits. Would we get a magnetic vacuum?
giantkiller @ Thanks to review, would be interested!
Regards!
sigma16
Don't mix Tesla transformer with single wire coils.   The tetrahedral device uses single-wire coils of very long wire length and high voltage positive pulses.  Remember that Spherics said if you double the amount of wire then you double the effect but the power applied remains the same.
The same magnetic field has to encompass all four coils.  You can use a large rheostat to adjust the current to the solenoid coil and connect to a battery.
Bulgar
In the "Tesla" design I wanted to achieve high voltage winding of tetrahedron and it worked. I think the problem is that they are magnetically coupled.
Long coils? This is new to me. How much longer? How to solve the problem of skin effect? /current will terribly small => low power of pulses/ The use of bifilar windings and delay group thought that to obtain the magnetic vacuum.
To keep the low frequencies? with the current scheme can not work with more than 300-400kHz for the oneshot 74123 multivibrators and mosfets. The external solenoid will reduce the required frequency to so?
I would be grateful if I receive a response to these uncertainties. And I can began to work. ;)
sigma16
Quote from: Bulgar on October 06, 2010, 04:41:24 AM
The "bifilar wire method", where both wores are pulsed and one is delayed is a method of pulse compression to achieve a higher voltage pulse that is shorter than the pulse you applied.   You can achieve the same results with higher voltage and a single wire coil.
Placing a solenoid around all of the coils will lower the required repetition frequency to the low kHz range.
The coils are not magnetically coupled.  They generate a field of force similar to a charge and this is produced sequentially to impart movement to the field.  Like charge in motion, it is inductive.
Bulgar
Giantkiller colleague spoke for 4-50kV. This is a lot and I can not imagine it applied to the inductive load.
About 310V Are? With the multiplier can pick up to 600-900V power supply.
Does it matter the direction of rotation of the field produced by XYZ, because spherics no mention of this. / According to a torsion theory should have /
How should foreign-oriented magnetic solenoid? / Such use and Stefan Marinov in Magvid, and perhaps for the same reason /.
Sigma16 @'ll be glad to know your ideas on what theory is based.
This technology will make the world a better place if people become humble.
Thanks guys! Hopefully one day  to we drink beer. :D
I plan to finish the stupid questions and gets to work.
С нами бог! /God is with us!/
