The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Kls
@ Paul
i forgot something,
there is a drawback with that speed.because of the limit of the EM interactions ,and that is the speed of light, all one could achieve would be something like... hmmm. breaking the sound barrier, or creating a shock wave, something like the Cerenkov effect.
tishatang
@Paul and All
In the early days of the TPU, I thought  it had to do with heterodyning and mixing of frequencies.
I now believe SM achieved rotation by the Lorentz O forces.  Link here:  (About half way thru the video for the demo):
http://youtube.com/watch?v=cSEtx5C2pkQ
Torsion field energy comes in from the aether and assumes a vortex shape as in tornadoes.  Turn the TPU over and it will not work because it bucks the natural flow.
I will try to explain proof of principle:  Take your four strand telephone cable and wrap some turns around a 4 or 5 inch form.  Remove and put some tape around to hold shape.   Strip sheath to expose about 6 inches of wire on each end.  Tape one color off as we will only use Three coils.   Take another piece of same cable and strip sheath as Paul described earlier.  Wind your 4 coils around the three strand ring coil at 90 degrees.  Instead of phone cable, This may have to be three stacked individual coils to form the ring?
The middle coil is only an electromagnet to provide the field.  I think SM used a ring of magnets to provide the field like was done in the above demo video.  Energizing the middle coil with a small battery is a quick way to prove the principle.  To use magnets, you would probably need to fashion some circular pieces of thin plastic to hold the magnets in place so you have all N up and S down?
The top and bottom coils have to have self resonance at the same frequency using trimmer capacitors and within the physical size of 4 to 5 inches and within the limits of the AC signal generator.  Make note of this frequency.  The AC goes through  two rectifying diodes, one for the top coil and one for the bottom coil. The other ends are tied together for common ground.
Now for the four  small 90 degree coils.  Two for each remaining ring coil.
One is the control coil driven slightly off self resonance frequency of the ring coils.  Do not match resonance frequency, but detune to prevent runaway!!!!  Does 5khz sound familiar?  These control coils receive AC from a separate generator, going through two diodes to match phase with the other signal generator.  Their opposite ends tied to common ground.
The other coil is the output coil.   The output coils have one their ends tied to common ground.  The other ends will be the output.  This will give us DC as the field rotates in one direction and a small 5khz ripple on top.  You guys will have to figure the electronic control circuit.  I am just giving what came into my mind's eye last night.
Waving a magnet might get the tuned resonant coils to start ringing a little, the almost in sync control coils will start the field rotating due to the Lorentz O force.  It should start slowly at first because of the weak fields.  But, because we are moving the way the natural torsion fields want to move, it should speed up?
This looks like the TPU physically and it should put out the same signals?  I think the early small TPU only used half the AC wave as in the above demo video.  The later TPUs used both halves, hence the need for two magnets to start.
Suggestions:
Try placing magnets under your existing coils and setups to see if you get rotation?
Maybe this principal could be used to create the virtual rotating field for the fellow with the alternator stator.
Hope this helps.  Good luck everyone.
Tishatang
kron
Quote from: Kls on May 29, 2008, 04:56:20 AM
@ Paul
About moving a field or field poles; There is no upper limit to that speed ,not even the speed of light itself and that's so because the field itself is not a particle which have mass, 0 like the photon or greater like any other particles. So in theory one could move a field created by virtual poles (aka a virtual magnet) at a speed much much faster then the speed of light.That would obey all known laws oh physics.
If so, no speed limit, a setup like Tesla's 382282, seeded with a certain freq. would have the poles moving across the circumference at the speed of light which means the coils on the outside of the setup would not be able to "see" the virtual magnets moving(they are moving at the speed of light right?so there is no time for em interactions) but it becomes even funnier if they can move at a speed higher then c(at even higher seeding freq.).In this case according to the relativity the secondary coils would "see" the virtual magnets actually moving backwards but that would be great ,that's a OU generator that would destroy itself, because bemf would work not against the virtual magnets but actually for them.Wow.That's really weird.
edit to add a nice link
gn0stik
Quote from: tishatang on May 29, 2008, 07:56:17 AM
@Paul and All
ding ding ding ding ding... This was a ringer of a post, in my opinion. However, You might want to start your own thread tish, as it would derail Paul's.
Note Stan said DC Pulses. This is also a very important part of what I was saying in my previous posts. The device Stan was talking about could be engineered to output power, or do other things as well depending on the pulse width, and center frequency. It's also important to note that too strong a magnetic field could kill the effect, we want high potential, low current, and a short current duration. Sharp rise time, sharp trailing time. NO RINGING. We're teasing the ether, to extract and create torsion fields. Ferromagnetic cores are bad to varying degrees, however it can be used to shunt the effect, or make it safer. High permeability, and resistant to saturation is what you would want. You would need a few devices that automatically switched back and forth with this config, to avoid saturation. I find it fascinating that the device Stan was discussing used a mu-metal core, which is used to shield against magnetism. I wonder what the precise engineering decisions behind this were. However, I would guess it's for stability, and safety, while avoiding any kind of saturation issues..
Genius really.
If we discuss this any further it should be in your own thread however. I remember when this video was first posted years ago. By Tao, I believe. Funny how things come back around. When I first watched this, my thinking on the operation of the TPU was too linear, and I missed the significance, save for a few tidbits.
Go read Aspden's work, if you haven't already.
Rich.
pauldude000
@Gn0stik
I don't mind. If the technique works, I am all for it. If it generates a rotating field, then it is worth trying. There is always more than one technique to skin any deer.
I have also been considering the effects of the rotating field on neighboring magnetic fields, from perm magnets, to the earths field itself. I have also been considering its interaction and effects with prevalent electric fields. If Kls or Tishatang want to post a theory, observations, possibilities, or thoughts, it is good stuff in my book.
In other words, I don't care how we get there, so long as we get there.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
