The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
pauldude000
@Tishatang
Example #1 has its magnetic field perpendicular to the toroid, and rotates through the center.
Example #3 has its magnetic field perfectly in line with the toroid and rotates around the circumference.
I hope that clarifies somewhat.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
tishatang
@Paul
What matters here is how you see things.  It has to work in your mind, because you are the one doing the "hands on" thing.  You have to design the circuits and build it to do want you want it to do.
Many thanks to you for forcing me to take a detailed look at the interaction of the field and coil using the car on the track analogy.  To see what is happening where the rubber meets the road, so to speak.  What was a fuzzy has now become clear and "ding, ding, ding, ding, ding," to quote gnOstik.  At the risk of being termed a whacko,  I am going to make the following claims:
Almost certain, SM used Lorentz O force for rotation.
Almost certain my theory about the 90 degree intersection of two coils  collecting (demodulating) the scalar waves as source of     power in the TPU is correct.
Almost certain my speculation about the caduceus wound toroid is correct and it is the collector.
We are going to make a new and improved version of the TPU that will make SM's version obsolete.
As I see it, SM finally achieved rotation and got some voltage.  Experiments led to more and better versions with better performance.  But no matter what he did, it was always temperamental and always had a heat problem.  He could not solve this problem because he did not know how he got the power.  Nobody in his group evidently knew about scalar waves or the caduceus coil.
After he achieved rotation, The collector, at 90 degrees, would start to open the gate and scalar waves would return some energy from the aether.  But the 90 degree crossing of a horizontal and vertical coil is not the same as the 90 degree crossing of the conductors in a caduceus coil.  A vertical coil and a horizontal coil might only convert 50% of the scalar energy, the rest going in to heat.  Had he used a caduceus wound toroid, he would have converted nearly 100 % of the scalar waves into energy with no heat.  No heat means better control and stability!  The caduceus wound toroid has been a well kept secret for 50 years!
Follow my logic and let us find out if I am a whacko?
First:  Draw two parallel line representing a normal two turn flat coil.  Now instead of a car on a track, we are going to substitute a rolling pin and rubber tubing filled with water for the car and rails.  As you roll the roller pin from right to left you will flatten the tubing, squeezing the water out ahead of the pin, thus creating a current flow to your left.  You will also cause a low pressure zone behind the roller which tend to suck the water along.
Next:  Draw two parallel lines as before, but this time they represent the outer edge of a short straight caduceus coil.  Place an "X" in the middle of the lines representing the crossing of the two conductors of the coil.  The source input leads place on your left of the coil.  In transmitter mode, we pulse the input starting with the top left of the "X".  Place an arrow here showing the current flow to the center of the crossing,  Place another arrow in the same direction on the lower right side after the crossing.  The current flow continues around and comes back to the crossing at the upper right corner of the "X".  Place an arrow here showing the current flowing to the center of the cross.  Place another arrow after the crossing showing direction of flow back to the source.  Now focus on the four arrows.The two on the top are both pointing towards the crossing.  Use your left hand and place your thumb pointing with the arrows towards the crossing.  Your index finger is now pointing in the direction the scalar waves are being transmitted.  This is active transmitter mode!
Now draw the same configuration as above without the arrows:  This time the picture represents a crossing of a caduceus wound toroid.  Instead of source on the left,  our conductor leads are now output.  We are now in passive receiver mode.  Picture the conductors as rubber tubes of water as in the first drawing of the normal two conductor example.  We place the roller pin on the right side and roll it to the left.  The roller pin now represents the rotating field moving to the left.  Place two arrows ahead of the pin both pointing towards the center of the crossing.  Place two arrows after the cross pointing to the output.  The water in our analogy is forced to cross and go directly towards the output.  Now look at the four arrows.  Using your left hand place your thumb in the direction of the two arrows pointing to the crossing point.  Your index finger is now pointing straight down, the direction you want to move the scalar waves forming the Lorentz O "Tornado".  Not only that, but remember, behind the pin is a low pressure zone actually wanting to "suck" the scalar waves in.  We have a scalar wave pump!
The good news is I think we can gently pulse the input and get a controlled startup once critical rotation speed is obtained.  The bad news is how do you control such a powerful beast from runaway?  The answer:  With another powerful beast.
We build another duplicate rotating field in the opposite direction.  Remember SM asked "What happens when you rotate two halves in opposite directions"?  Answer:  It is to control the beast.  Like a large "Tug 'O War" with fifty men on each side pulling against each.  One additional man on either side can slowly move a great force in one direction or the other.  The two opposing fields create the gyroscope effect of the TPU?
To picture two opposing vortexes go here:  Scroll down to item 6.5:
http://www.divinecosmos.com/index.php?option=com_content&task=view&id=100&Itemid=36
Partial quote from 6.5"
"The next image that we see below comes from the work of Dan Winter, showing the whirlpool to the left, the torus formations in their opposing rotation in the middle and then a diagram from Dr. Walter Russell to the far right that shows how they come together and form a sphere.  (From the image, we can see that Winter makes the simple mistake of not seeing that the two tori are both contained in the same spherical space and are able to swirl inside of each other, since he has visualized them as more akin to two donuts that are sitting on top of each other.)"
What happens if you sightly over compensate and have excess counter rotation?  I am going to speculate that the unit will either lose weight or you get "Cold Electricity".  In other words demodulation with positive spin equals electricity as we know it.  Demodulation with negative spin equals cold electricity?
@All
Each of you will have to decide if I am some kind of delusional whacko, or maybe, you just might want to save this post?
Tishatang
pauldude000
@GeniusDudeWhereverYouAre
I need someone to answer a question for me. If an electrical path doesn't exist, current doesn't flow...right?
Then explain to me enough juice to run three leds from collectors not electrically connected to control coils I am pulsing.... with ONLY ONE LEAD from a function generator? ? ? ? ? ? ? ? ?
I looked down, and realized that I had forgotten to hook up the ground lead. It was laying there right on the wooden table, the positive hooked to a experimental two CC tpu I just wound tonight, with one coil in series with the other. The collector was putting out 15v steady as a rock, with enough juice to run three leds at about half brightness.
Can somebody explain this?
Paul Andrulis
otto
Robb
@ Paul
Hello Paul I'm a newbie ??? on this matter, but is there an answer for you in:
http://video.google.com/videoplay?docid=-5738531568036565057
at min: +- 31 ?
Greets,  Robb
