The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
poynt99
you're right grumper, it's differentiation. probably nothing more.
works with capacitors too. theoretical output peaks are 2xVi (as i already mentioned).
integrate the differentiated wave form and you're back to the original.
see, trolls aren't all that bad Bruce, they can learn too  :P
so Paul, still and once again, there's nothing too special about the output from this setup.
oh and grumpy, you nailed it right on man, Paul and i are MIBs, or MIB wannabe's, (haven't decided yet). thanks for busting us man, that's quite a load of guilt off our sholders. now we can continue free, like the wind....  ;D
poynt99
@ Duff,
you're probably the only one interested in this, so i'm just posting the netlist. it's the simple single inductor version, which won't give the exact results as Paul's but close enough. you'll see the differentiation effect and voltage peak anyway:
Vgen 1 0 Pulse -10 10 0 10n 10n 6.25u 12.5u
Rgen 1 2 50
L1 2 3 20uH
R1 3 0 1.2
poynt99
Quote from: Bruce_TPU on July 23, 2008, 10:49:09 PM
Hey Troll,
Trying to mock a builder here is not cool.  (Bad Troll!!)
NOW, if you actually EVER built anything..... OH, never mind, that will never happen.  Time to crawl under your bridge, BEND OVER, and wait for the KICK!!!  IT will be there, i assure you ;)
:D LOL :D LOL :D LOL
whatever bruce, chirp chirp chirp away...
i'm still waiting for my kick  :P
pauldude000
Hmmmmm. Interesting.
Two people trying to through out bull**** as truth. Both seemingly opposing, but serving the same end. Same corporation? I don't need to name any names. It should be clear to any reader.
To one of them, nice switch. Nailed to the proverbial wall with the back-emf concept, switched to "differentiated pulses" at the drop of a hat. I like that term.... sounds impressive, yet completely meaningless. Just like "transformer action".
To the other: No, you wouldn't know Tesla if he bit you in the keaster, apparently. The "Death Ray" used the magnifying transmitter for power only, to drive a linear particle accelerator. (Yes, particle...) Oh, I forgot, you ignore what Tesla himself said. You seem to know more than him.
I don't think you are MIB gentlemen, I think you are worse than MIB. I think you are posers. Attention hounds. Intellectually effete.
If you were MIB you would be fired for being so lousy and transparent at the job. I hear quite a bit of talk, mostly BS, so why don't each of you do something more enlightening and satisfying, like build something.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
forest
Paul,
What do you think about my idea that TPU coils are parallel connected pancake coils or maybe even each of them is bifilar ? The idea is a coil which is segmented , each segment is acting as separate coil yet adding power to the others in chain. (This would be the same what Stanley Meyer did, however Meyer connected them serially to step up voltage and limit current)
There is also one interesting idea - positive feedback. AFAIK flat disc rotating in magnetic field is summing his magnetic field with external magnetic field.Pancake coil is flat and current therein is rotating, maybe there is no difference between rotating disc and rotating current inside.Isn't that only a point of view ? I bet that two ideas are involved because IMHO they fit exactly SM words.
