The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
Spider
Or go outside in a thunderstorm, with a big iron pole in your hands, and wait a for while....
Greetings Spider.
When a magnetic field, produced by a moving electric field, is moved longitudinally a tempic field is produced.
sparks
     We drop a rock on the surface of a pool we get waves of energy to the edge of the pool due to the differential viscosity between air and water.
   We drop a rock under the water we get vortex currents.
    I'd say the viscosity parameters of an energy circuit are quite important.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
Quote from: sparks on July 26, 2008, 10:58:25 AM
Bascially imparting viscosity parameters to electrical phenomenon.
Yes. We see nothing in the space. But you move it you create potential / potentiallity.
That  is why I mentioned the mercury in a vaccum. I am using light switch vials. At a very high speed input it looks like a crystal.
Don't even try that experiment. At the speed that fracturing occurs, glass looks like jello. The mercury will shatter in all directions. A Hutchison micro experiment. The mercury can't move that fast so it shatters. Hit it with a hammer instead. Slower speed.
High speed, low voltage. Raise the voltage lower the speed. And anything inbetween. One just has to find the material that responds in a band of operation.
The kick? It's there. Space reflects back a thousand fold. Like any other medium it represents resistance to us and wants to be balanced at the band or place of existance where that material resides. We are jacking it out of place. Physically and with frequency. 8) That is why fast off times are needed. We alleviate the opposing pressure quickly so the displaced material can return quickly. It kicks when it crosses it normal place of balance and rings in quiesence showing a damped wave.
And the things that exist right beside respond too. Ripples. You cause equal waves in water and every 7th one is taller. Amusement water parks have to stop their wave machines every so often because of the power build up of the contained water. Got kicks? We don't produce them they occur via the harmonics or speed at which we ring the destination material. No different than a steel handrail in a stairwell producing echoes. ;)
The fastest current is spark gap. The highest voltage is flyback or ignition coil. This was productive.
--giantkiller. Got Keely?
sparks
   The spark gap is unique as it is capable of altering all three parameters of the electrical conductor field in one event.   The dielectric information / the magnetic information (inertial electrical information)/ and the electrical density of the conductor field (gap). I remember somewhere of reading that Tesla found the orientation of his disruptor to the primary of his transformers was real important.  I wonder if SM's tpu's control windings are an attempt to make a big spark gap in which he inserts a collector winding.  Altering the dielectric magnetic and density of the interior of the solenoidal coil wherein lies a collector mass.
Think Legacy
Spread the Love
Bruce_TPU
Quote from: Spider on July 26, 2008, 11:25:34 AM
Wanna see a kick, build a kickcoil.. ;D ;D
Greetings Spider
Ahh, perhaps there is a glimmer of hope....someone actually listening to Spherics posting of the kick coil using a delay pulse.  So strange that no one will listen and even experiment with his second post.
Sometimes, I suspect that some here are afraid to actually find out how the TPU really does work.  But glad to see that not all.
Great Job Spider!!  I look forward to more posts about those delay pulse kicks.!
Cheers all,
Bruce
