The TPU uncovered? (A PROBABLE technique.)
Started by pauldude000, April 09, 2008, 08:35:14 PM
innovation_station
where is that other guy that keeps playing peek a boo?
lol
you know who u r
join in ...   bro ...
you got this licked i know it...    8)
there is so much info on this site bout free engery most have no idea where to look it is everwhere!!
oh welll  so b it
ist
sparks
   I believe the delay coil absorbs the hi freq pulse energy so a voltage gradient is set up between the bifilar elements.  This is all well and good for seeing the kick.  But not so good for concentrating the the kick invested energy.   Series connecting the two bifilar ends will setup a higher turn to turn capacitance for the energy input.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
@sparks,
On my Hubbard the 4 bifilars are terminated that way. I drive them in series and in parallel with the center. My pulses aren't correct tho. gotta fix it next session. Like EMD said 'it could also be the distance'. I can change that too. And also change to air core.
Not mine but the red one is output and two greens are input. They are setup as single channel inputs. Could push towards the center. A similar twist to the ozone NT568177. This pic looks iron/ferrorite core
--giantkiller.
Bruce_TPU
Quote from: sparks on July 28, 2008, 09:38:14 PM
Hi Sparks,
I have already explained in my other post how to "harvest" the kick.  A collector must be used, and the "Kick" is rotated.
@ ALL
I would STRONGLY suggest doing it Spherics way, before changing anything.  After you can produce the kick, change what you want.  I am sure a couple of brilliant folks here, will come up with a much better way of harvesting the kick, then Steven Mark did, but for the rest of us who are not that brilliant, we might just rotate and collect it. ;)
Put away your theories, and ideas, pride, ego and arrogance, and just try the simple experiment.
Or you can continue to play the guessing game with each other, getting nowhere.
"The Kick Comp Poem"
"There once was a group of men,
Who dreamed of a time when,
They would know how to make the kick,
If they only knew the trick.
It turned out not to be tough,
But none would do the stuff,
For them it was too easy,
And so they thought it measly.
But then some did awake,
Realizing what's at stake,
Once they saw the kick,
That was only part of the trick.
But now they must know,
A kick was only part of the show,
For a comp field now was born,
Anguish for those who scorn.
The North always faced middle,
The Comp field then could fiddle,
An anomalous magnetic field,
Radiant Energy could now be reeled.
Three of these did rotate,
At 120 deg phase state,
Around the collector it went,
And to the collector the electrons were sent.
At a great speed they go,
Frequency's dependent on circumference, you know."
Spherics:
Quote from: spherics on March 24, 2008, 11:56:27 AM
It appears I have been too brief in my presentation. I truly believed that there would be a group here who would be able to make the leap between the Steven Mark devices you are familiar with and the design that I showed.
Firstly although this has been mooted I am not Jack. All I will say is the interview says more about the character of Jack than it does Steven Mark. I will also add that the SM device uses rotation. I say this without doubt and Jack is wrong in saying rotation is not necessary.
I will now talk about the Steven Mark designs you have seen in the videos and the like so you will understand why my design at the start of this message works.
The SM designs all work on the same set of principles. A pulse into a coil generates an expanding magnetic field. The magnetic field comes into being by an underlying patterning of the ether. It is a cascade action on the part of the ether that causes the EFFECT of an expanding magnetic field. If you then cause a second magnetic field to expand through the same space as the already expanding magnetic field, a specific cascading action, a pattern is setup in the ether which is the EQUIVALENT of a magnetic field and has many of the characteristics of a magnetic field. By this I mean it will interact with metals, and cause the EFFECT of a current, IF the field is moving across the metal.  I will refer to this field as a COMP field from now on. But please be clear this COMP field is in addition to the expected magnetic field. This COMP field, a patterning in the ether, is dampened and effectively nulled by magnetic metals. This is why if you are using an iron core in the coils named control coils you will never get a working TPU.
No doubt this may be disconcerting to many who have fond references to baling wire, iron wire and the like. I will now digress onto the circumstance surrounding the initial eureka moment as I understand them. Audiophiles who frequent this watering-hole will no doubt have heard of QUAD ESL electrostatic speakers. An essential design element is the incoming signal is sent into, I believe, 7 or 8 progressive delay elements. These elements delay the signal by microseconds each time.
As part of experiments, associated with what would become his 3D spacial control patents, he was using these delay elements with custom made bifilar wound voice coils (i.e. air coils) and unexpectedly detected an anomalous signal on his spectrum analyser.
Steven Mark created his own delay elements using iron wire after several years of intermittent experimentation. The technique was to carefully wrap a bifilar air-coil using copper wire. The longer the length of copper the better but using identical lengths. The two coils were connected to the SAME pulse waveforms in parallel so that the magnetic field is additive NOT canceling. The delay element was added in series to only one of the coils that made up the bifilar coil. The delay coil was made from insulated iron wire wound into an air coil. An oscilloscope was connected to both COPPER coils. The setup would be pulsed with a dc offset square wave (i.e. 0 to 20V not -10 to 10V) at the resonant frequency of the bifilar coils. The tuning consisted of cutting the iron wire down in length until an unexpected pulse/signal appeared. This pulse is the kick. I will refer to these tuned bifilar coils as kick coils.
You are privy to the information that the COMP field is nulled by iron. Those who so wish may like to take some time to fully comprehend the frustrations of closely packing the delay and bifilar coils together only to find the unexpected pulse was no longer appearing!!!  This is what SM had to contend. And Jack says SM was not technical. Bunkum!!
From traditional electrical engineering view point the kick coils for a particular quantity of energy now put out the expected magnetic field but also put out the COMP field which has effects like a magnetic field. In a world that excludes the ether, these coils are overunity. If the world took into account the ether, then the coils would not be thought of as overunity.
The magnetic field is now larger than expected. All that needs to be done is to rotate this field in a circle and intercept the field with an output coil. The captured energy is greater than the input energy because of the energy apparently created by the COMP field. If you arrange all N poles of the kicker coils so that they point towards the center and pulse each coil in turn you will get a rotating magnetic field. There are many ways to create a rotating magnetic field. A secondary effect of a rotating field is the entrainment of the COMP field so that the pattern in the ether is partially additive. A big problem was the iron in the delay coils. It was found that a large solenoid fed with a DC current to produce a static magnetic field around all of the kicker coils allowed the kicker coils to be tuned with the iron delay coils in close proximity.
Intercepting only N poles of the kicker coils means you get a DC output along with a smaller induced ripple from pulsing the kicker coils.
Feedback of the output into the input was achieved using toroidal saturable inductor switches. I've copied the picture from other messages of the inductor switches. Refer to the patent for an example to see how these switches are used. Early designs used a small magnet to bias the saturable inductors.
All SM devices had small batteries to power the LC oscillators. The LC oscillators were used as control pulse currents to the saturable inductors. To start the process high voltage capacitors were step charged, this is why the coils took time to start-up! The first few pulses came from these pre-charged capacitors being switched via saturable inductors. Part of the DC output was feedback to keep the capacitors fully charged.
My design shown at the very start of this message thread eliminated the need for an iron delay coil because the pattern is set up in the ether outside of the influence of copper metal of the control coils. It directly allows the COMP field to be generated IN FREE SPACE. By placing the output toroidal coil within this free space the COMP field is intercepted. The complete lack of any magnetic materials within this design is what allows this to happen.
I do believe there are elements of information here that you will not have been aware of before. I trust this is enough to convince at least some of you to reflect and ponder more seriously on this material.
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/19820016542_1982016542.pdf
Grumpy
I will be absolutely and utterly shocked if anyone actual winds this coil.   So many like to talk to the talk, but they can't walk the walk - and that is the cold hard truth.  Such a waste, really.
I just peeled off 100 feet twice, 30 awg, and placed each on a small spool.  Will wind it tomorrow.  Got to find my bailing wire - have a spool hanging somewhere.  Winding loose bifilar manually sucks - as we shall see.
See how the "bots" are?  Scope shots.  Endless details.  Then if you show the goods - more BS.
Like I said earlier - I see others winding or I walk.   Stick that in yer pipes and toke on it - and get off yer asses.
        -Frank Edwards
