Stubblefield coils (bifilar) and speculations
Started by Pirate88179, April 09, 2008, 09:43:54 PM
resonanceman
Quote from: argona369 on May 05, 2008, 10:27:32 PM
You don?t think the Electron shuttle looks like Tesla?s wireless energy?
(the missing transmitter)
sad, and hostile.
i deal with electrostatics. i have a 30 cm Wimshurst i built.
does that count as "builder"?
Cliff,
Cliff
Sorry
I didn't see any  mention of  your  Wimshurst machine   on the links .
To be honest I didn't  see  the electron  shuttle  as  tesla's  wireless transmition ............but it  could be .
I  was wondering  about if it  could be adapted to  efficient HHO production
One of my  projects on my want to do list is a tesla based   electrolizer .
Imagine  a  beaker  of water  placed in the  center of a  fairly  low voltage  tesla coil secondary .
2 sheets of stainless  steel  .......one  longer than the other can be wound into a coil    the  smaller  one  would  have a ground  wire attched .
there would  be a  variable  resistor  on the  ground
with the   stinless steel   coil  in the  water  ..........the  longer   piece  of steel  will pick up more voltage from the  tesla coil  secondary .
you now  have   a  pair of  electrodes   in water ....... you can  control the  relative  voltage  of the  electrodes with the   resistor  on the ground wire .  .......and the whole thing is in a stong  magnetic field
now ............my  question  for you
would  your  electron  shuttle  add to my  idea  if I was to do something  like   put  large plates on each side of my  stainless  coil  and  shuttle   electrons  back and forth?
Localjoe
@bill
I bet your inital cap rod setup woudl run a small digital clock. next to positive acctually.
        joe
GET THIS ONE - Bush wants to stop Iran from enriching uranium .. now as oberman said and others any drunk coke head can find out how to do this not just bush.
Also in reality Google has provided this info for some time.. so heres my point.
It's OK for GOOGLE TO PROVIDE INSTRUCTIONS FOR URANIUM ENRICHMENT but not OK FOR FOLKS TO SHARE TORRENTS OF MUSIC THEY POTENTIALLY OWN> AS WELL THEIR GOODS SHOULD BE SEIZED AND CHECKED AT AIRPORTS For copyright infringement.. ?????
This is the world we live in. More concerned if some exec doesn't get his buck than if some terrorist blows us to hell..
Pirate88179
@ All:
For some of the newer folks, here is a video of an electrode set up where he claims 1.1 vdc and 1.8 amps.  One of his electrodes is like a very long grounding rod used in home electrical applications.  Thought you all might like to see it.
http://www.metacafe.com/watch/834037/battery_hack_the_planet/
@ Joe:
I will have to look around for one to give it a try.  I honestly never considered trying anything more than the leds at that time.  I think the more variety of things we can power from what little we have would be cool.
Pirate88179
@ Jeanna:
Here is a video of a guy who also wound a secondary.  Since you have been doing a lot of this work, I didn't know if you had seen this one or not.
http://www.metacafe.com/watch/yt-BmNoLfjIEac/stubblefield_earth_cell_battery_demonstration/
DrStiffler
Quote from: Pirate88179 on May 06, 2008, 01:46:08 PM
@ Jeanna:
@Pirate88179
BIll, I'm sure I am making a mistake by talking on this thread as the last time on a different but related thread some dude that showed a picture of himself 'Fat, pimple faced and discussed his first date  "Love"  life' chased me off.
Any way I have watched both threads and I see a common error in how one assumes they are getting some place. First current or voltage are irreverent unless considered together. To get to watts the very simple formula of P=EI can be used where P=watts, E or V = volts and I = amps. Now 1amp X 1volt = 1W as does 0.5amp X 2volt = 1W. When you see someone showing 1.2V then connecting the source together and showing for example 1amp, does not mean 1.2 X 1 = 1.2W. The reason being the meter in amp measuring mode should present a very low impedance (resistance) if you will (else it would act like a resistor across a load and dissipate energy. The last video you referred to should have measured E or V and I together, then we could see what was really available.
From the brightness of his LED one can be sure that the so called voltage drops a lot when even the LED is connected, reason is no matter how it is shown the LED is really very dim.
All I am saying is you want to look at V and I together in your work and if you use the very simple approach of P=V X I you will see where many of the reading found by experimenters are about the same when it comes to P. Yes indeed V may be higher, but I is lower, then I is higher and V is lower and the product stays about the same.
Sorry for jumping in here and don't send .... after me.
All things are possible but some are impractical.
