infinity transformer, no back-emf transformer
Started by shimondoodkin, April 16, 2008, 11:37:05 AM
shimondoodkin
as i understand coils when a current flows in a conductor it creates a magnetic filed like rotating in a direction.
in a transformer there are two coils. when you pass current in the first it creates magnetic filed. when you withdraw current from the second coil because of flow of the current in the second coil it creates a magnetic filed that like rotates in the opposing direction to the magnetic filed of the first coil. the filed of the second coil that opposing destroys the magnetic filed of the first.
and then there is nothing.
my idea is to rotate the magnetic filed that going in the core by 180 degree at the other side.
so when i will take current from the second coil the magnetic filed that will be created
will be in the same direction of the magnetic filed of the first coil.
i propose to create a core in form of infinity sign (like 8 rotated on the side)
this core may be used with a transformer.
may be it will be possible to create accelerating magnetic fields and a no back-emf transformer
pese
shimondoodkin
do you say that it is the same way?
is there a different way to retore a magnetic filed by 180 degrees?
also attached a different idea.
i do not sure about it.
gyulasun
hi shimondoodkin,
have a look at this link:
http://www.amasci.com/elect/mcoils.html      a similar conception?
resonanceman
Quote from: gyulasun on April 17, 2008, 12:09:28 PM
hi shimondoodkin,
Does anyone  know of a source  of  high  mu  wire  like   they talk about in this link?
gary
